Hey all
Bought an item off this member around 2 months ago, have been in contact since with several excuses saying i will send etc i cant refund the money i have none etc
Basically just want any member who knows details on pitchd to send me a PM, weather it be address, phone number etc anything would help.
Have given him chance after chance after chance to do the right thing and he has simply ignored me over and over.
I have contacted Blitz who didnt get back to me about it all after I sent him all the PM messages between us and information about it, I understand he's a busy man so if he simply didnt have the time to follow up thats fair enough.
Any help would be greatly appreciated otherwise i've simply been screwed out of money which i dont think is fair from a member who's on here daily!
Thanks for any help in advance peeps.
Jazza
https://www.sau.com.au/forums/topic/84673-help-needed/
Whats that dude....??
Thanks to those who have PM'd me, should have his phone number shortly.
Any more help would be appreciated :)
phone number wont do you much good mate...all you can do is abuse him, big deal, he'll hang up.
you need his address...and you need to be able to walk the walk if you're gonna talk the talk
https://www.sau.com.au/forums/topic/84673-help-needed/#findComment-1534189
Im well aware of that dude :)
Not planning on abusing him, simply asking him wat hes doing.
If he replys with a shit attitude ill give his details to the police who can deal with it!
As it stands i have his full name, bank details etc
Edited by jazza08
https://www.sau.com.au/forums/topic/84673-help-needed/#findComment-1534191
I only bought a small item off him! I wouldn't dare dealing with him again weather the item is cheap or expensive unless you can go and pick it up with cash in hand (and if so pm me his address HAHA). I think as a trader he should be banned on SAU for the lies and stealing.
Can we try to keep on topic plz peeps, help would be appreciated :)
https://www.sau.com.au/forums/topic/84673-help-needed/#findComment-1534200
If pitchd is the same Adz that I know, then he must be really busy or something. Don't jump to any harsh conclusions, and I'll see if he's got any logical explanations next time I chat to him. Maybe PM him on nissansilvia, as he's more active on there.
https://www.sau.com.au/forums/topic/84673-help-needed/#findComment-1534205
Hes on the forum nearly every day, go look at his profile dude.
Yes its Adz (Adam) and he's been avoiding me for 2 months about this.
Im happy to recieve the item OR have the money back but neither is just no good for me...
Any help would be appreciated FunkyMonkey :) thanks mate
https://www.sau.com.au/forums/topic/84673-help-needed/#findComment-1534211
  • 3 weeks later...
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
