Hey everyone,
well im soon to be the owner of a 1994 Skyline R33 GTS and i was wondering if i needed to change the stock battery that comes with this car.
The system:
1 x Pioneer DEH-P8650MP (head unit)
1 x Alpine SWX-1242D Type X 12 (sub)
1 x Kicker KX350.4 350w 4 ch (speaker amp)
2 x Focal K2 Power 165 KP 6.5" (front splits and rear)
1 x Alpine MRD-M605 600W Mono Amp (sub amp)
Do i need a new battery from the stock one? or will the stock battery do just fine and run this system with the car off for around 2+ hours and a bit with the car off?
If i need a new battery, what would you suggest?
Thanks for the help :)
https://www.sau.com.au/forums/topic/84748-my-system/
A bigger battery (move battery clamp over to the bigger setting) is a good idea if you get something over the stock ~280CCA level. Failing this, you can buy large capacitators from car audio places which can smooth out issues you may run into. If your headlights dim with a hard bass-hit, run the big capacitator.
If you run into problems with your stereo after that, then change the battery... you may not need to change it at all!
Oh... I think the battery clamps are the "smaller" size to accept "small" post batteries... you may need to change the clamps over to brass/gold "large" terminals (which usually have other inputs on the terminal for power wires such as amps)
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1535751
go down to the closest battery world, and they will give you the right advice on which battery you should run for best power for your amps,
i got told to use a camping battery, which last me 8 hrs of usage when the car is off, and my system puts out 145.1 DB in my r33 skyline
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1537133
fit the biggest odyssey battery you can fit. i currently have a yellow top in my '71 capri which has no computers etc in it just a sh*t load of stereo gear and it doesnt last 30 mins. the best i have found for large stereo are odyssey batteriers have one in my 32. top batteries. also upgrade the battery before worring about the cap.
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1540377
When purchasing a capacitor, talk to a knowledgeable salesperson about your choice in capacitor. Capacitors are measured in farads, and if you get the wrong rating capacitor, it can actually drain your battery more than running without a cap. Upgrading the battery may not be necessary to begin with, and i suggest waiting to see whether you have any issues with your current battery. Dimming of the lights with a bass beat is somewhat a sign, but even deep cycle batteries are known to still dim, largely due to the fact that the altenator has not been upgraded. Any further questions, dont hesitate to contact me.
Cheers,
Nasha
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1548953
this is the no nonsense way of doing it. have the current draw of the amplifiers handy ( or fuse ratings . ) if it has multiple fuses add them together. add that to the existing car battery and they will give you the correct one.
look at:
exide
Absorbed Power ( i sell these - great battery.)
optima
oddesey.
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1556557
no cap. thats what the battery is for. a cap is a bandage for a bigger problem.
Couldn't agree more.
Dunno about over there, but Optima yellow tops can be had for around $400 here in NZ and Orbital Blue tops are about $340.
By the list of your gear, I don't think you would need to go to these extremes, but they are good batteries. Maybe something like a Champion 500cca or similar would do the trick. From memory the model is something like 125L or 126 maybe?
Deep cycle batteries allow you to run the battery flat and recharge them many more times than a 'normal' battery.
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1559042
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
