Hey everyone,
well im soon to be the owner of a 1994 Skyline R33 GTS and i was wondering if i needed to change the stock battery that comes with this car.
The system:
1 x Pioneer DEH-P8650MP (head unit)
1 x Alpine SWX-1242D Type X 12 (sub)
1 x Kicker KX350.4 350w 4 ch (speaker amp)
2 x Focal K2 Power 165 KP 6.5" (front splits and rear)
1 x Alpine MRD-M605 600W Mono Amp (sub amp)
Do i need a new battery from the stock one? or will the stock battery do just fine and run this system with the car off for around 2+ hours and a bit with the car off?
If i need a new battery, what would you suggest?
Thanks for the help :)
https://www.sau.com.au/forums/topic/84748-my-system/
A bigger battery (move battery clamp over to the bigger setting) is a good idea if you get something over the stock ~280CCA level. Failing this, you can buy large capacitators from car audio places which can smooth out issues you may run into. If your headlights dim with a hard bass-hit, run the big capacitator.
If you run into problems with your stereo after that, then change the battery... you may not need to change it at all!
Oh... I think the battery clamps are the "smaller" size to accept "small" post batteries... you may need to change the clamps over to brass/gold "large" terminals (which usually have other inputs on the terminal for power wires such as amps)
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1535751
go down to the closest battery world, and they will give you the right advice on which battery you should run for best power for your amps,
i got told to use a camping battery, which last me 8 hrs of usage when the car is off, and my system puts out 145.1 DB in my r33 skyline
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1537133
fit the biggest odyssey battery you can fit. i currently have a yellow top in my '71 capri which has no computers etc in it just a sh*t load of stereo gear and it doesnt last 30 mins. the best i have found for large stereo are odyssey batteriers have one in my 32. top batteries. also upgrade the battery before worring about the cap.
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1540377
When purchasing a capacitor, talk to a knowledgeable salesperson about your choice in capacitor. Capacitors are measured in farads, and if you get the wrong rating capacitor, it can actually drain your battery more than running without a cap. Upgrading the battery may not be necessary to begin with, and i suggest waiting to see whether you have any issues with your current battery. Dimming of the lights with a bass beat is somewhat a sign, but even deep cycle batteries are known to still dim, largely due to the fact that the altenator has not been upgraded. Any further questions, dont hesitate to contact me.
Cheers,
Nasha
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1548953
this is the no nonsense way of doing it. have the current draw of the amplifiers handy ( or fuse ratings . ) if it has multiple fuses add them together. add that to the existing car battery and they will give you the correct one.
look at:
exide
Absorbed Power ( i sell these - great battery.)
optima
oddesey.
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1556557
no cap. thats what the battery is for. a cap is a bandage for a bigger problem.
Couldn't agree more.
Dunno about over there, but Optima yellow tops can be had for around $400 here in NZ and Orbital Blue tops are about $340.
By the list of your gear, I don't think you would need to go to these extremes, but they are good batteries. Maybe something like a Champion 500cca or similar would do the trick. From memory the model is something like 125L or 126 maybe?
Deep cycle batteries allow you to run the battery flat and recharge them many more times than a 'normal' battery.
https://www.sau.com.au/forums/topic/84748-my-system/#findComment-1559042
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
