i only have this pic. had a really great pic of the socket on the wiring loom. with all the numbers pointed out. but lost it when my computer crashed :Paranoid:
so if any one have some thing they recons would be the pic im talking about i would apprecate if they could give it to me *plz*
Thanks for this info guys!
I went to install it and 'pin 7' does not have a wire running from it so i stuck a wire running to the shift light and hooked up the red and black wires but when i got to the rpm it was suppose to light up it didn't do anything.
Does anyone know what coloured wire comes from the the back of the tacho?
thanks again for the help.
It'll be there, just make sure your looking at the ECU and diagram the right way :P:D
Your tacho hooks straight upto pin 7 (and your ABS looks at it as well). If your tacho is working, then it'll be there.. :uh-huh:
I could be wrong here (shocking memory) but I think the tacho wire (pin 7) is brown with a yellow stripe???
J
Thank you to every one that helped me out!
I fitted it and it works great.
The wire was exactly were you said it was jay i was looking at it upside down... But when i look at the diagram it still looks like it should be the other way round...
For anyone out there reading this about to do there own my R33 GTS-t had a yellow wire with a blue strip through it as the tacho wire!!
Thanks again for everyone's help will post a pic soon.
  • 4 years later...
THANK YOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i have been looking at google all day for wireing diagrams and all the links to the pages with the pin digrams and wire colurs were bad links this solves that gauges issues :D hope fully ill test it tonight :domokun:
lol the funny thing was i tried here first didnt find it thou dose any one know wich wire the stochie (lean/ rich) meter goes to i have a Mechanic mate who wired it up but it dosent seem to display corretly usually i would trust his judgement but he wired up the same gauge in a gtir pulser and it dosent seem correct either
he wired it to the o2 senser in the engine bay i think i wasnt paying attention should it be wired to that or the computer? i dont know enough about the gauge
it seems incorrect because at idle when cold its stochie at idle when its warm its leen but as soon as u touch the gas pedle it super rich and is constantly theres no middle its either lean or super rich it dosent matter how slow u take off either
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
