i only have this pic. had a really great pic of the socket on the wiring loom. with all the numbers pointed out. but lost it when my computer crashed :Paranoid:
so if any one have some thing they recons would be the pic im talking about i would apprecate if they could give it to me *plz*
Thanks for this info guys!
I went to install it and 'pin 7' does not have a wire running from it so i stuck a wire running to the shift light and hooked up the red and black wires but when i got to the rpm it was suppose to light up it didn't do anything.
Does anyone know what coloured wire comes from the the back of the tacho?
thanks again for the help.
It'll be there, just make sure your looking at the ECU and diagram the right way :P:D
Your tacho hooks straight upto pin 7 (and your ABS looks at it as well). If your tacho is working, then it'll be there.. :uh-huh:
I could be wrong here (shocking memory) but I think the tacho wire (pin 7) is brown with a yellow stripe???
J
Thank you to every one that helped me out!
I fitted it and it works great.
The wire was exactly were you said it was jay i was looking at it upside down... But when i look at the diagram it still looks like it should be the other way round...
For anyone out there reading this about to do there own my R33 GTS-t had a yellow wire with a blue strip through it as the tacho wire!!
Thanks again for everyone's help will post a pic soon.
  • 4 years later...
THANK YOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i have been looking at google all day for wireing diagrams and all the links to the pages with the pin digrams and wire colurs were bad links this solves that gauges issues :D hope fully ill test it tonight :domokun:
lol the funny thing was i tried here first didnt find it thou dose any one know wich wire the stochie (lean/ rich) meter goes to i have a Mechanic mate who wired it up but it dosent seem to display corretly usually i would trust his judgement but he wired up the same gauge in a gtir pulser and it dosent seem correct either
he wired it to the o2 senser in the engine bay i think i wasnt paying attention should it be wired to that or the computer? i dont know enough about the gauge
it seems incorrect because at idle when cold its stochie at idle when its warm its leen but as soon as u touch the gas pedle it super rich and is constantly theres no middle its either lean or super rich it dosent matter how slow u take off either
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
