R33 Gtst Tail Lights
Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst. I posted a link to them sometime in the last 2 weeks, I'm sure.
From memory and please correct me if I have this wrong, the nismo that come with half shafts are specific for that diff centre. You may be able to find Nissan ones that match up but you'd need to understand what nismo are doing. Best option is get a pair of 5x1 axles, they usually don't cost that much and direct swap over for the 3x2(6 bollt)
AFAIK, the length of the shafts has NOTHING to do with the ratio of the diff.
It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
