I was reading the new HPI mag and read something about building a 2.4 ltr RB20, it said you use a gtr crank and rods with 4AGZE pistons.
Anyone built/heard of one locally. For the price of a stuffed rb20 it would be as cheap as buying a rb25 probably with something a little different.
https://www.sau.com.au/forums/topic/8478-rb24/
  • Replies 45
Posted Images
ok I have heard of
rb 2.2, = tomei larger pistons only
2.3 bigger pistons 81-81 mm with rb25 crank and rods
2.4 with the tomei pistons and rb26 crank and rods there is machinig requiered but not sure what
2.45 special hks cranks rods etc and dispalyed on my site
do a search on the sdu foums it has been disussed heaps personally I would only do the tomei pistons or copies 82 mm cause I know some one who made around 600 with this combo.
and decided againt the 2.4 kit cause and rb 25/26 was chaeper this was in japan
meggala
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123615
Guest Works Auto
Guys im in the process of building a RB24 for my 32 as yet ive only got the 26 crank and rods havent yet sussed out what im gonna do for pistolas but my mechanic says he has it sorted so we will just have to wait an see what goes.
Im nearly finnished my upright manifolds for the twin TBO's and the 100mm bar n plate core going into my standard GTR cooler along with the custom plenum with 76mm throtle body, GTR injectors, after market rail and GTR pump it should go a bit better than a standard RB20.
Ill post reports and pics as they are available.
Cheers
Ross
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123761
Guest Works Auto
Im sure you have heard of ND4SPD well he is a mate and he is doing the mechanical work as for compression well im an office jockey/salesman so id have to ask him about that so ill let u know.He also seems to think the RB20 pistolas wil fit with the 26rods and crank,.....Cant see it myself but he is the mechanic so i guess he would have a better idea than me. We got a few RB20 blocks and shit around so we will dummy together one before we do it to make sure.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123788
Yeah I heard of him, didn't know he built engines. I would agree with Meggala, that to get the increase in displacement that your after you will need bigger pistons. Luckily the RB20 blocks are relatively cheap so you can do some experimenting.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123804
The main disadvantage, as I see it is the RB20 cylinder head.
You are going to be stuck with this, even after an increase in capacity, it will limit the final power potential.
The RB25 and RB26 have a far better cylinder head design, and thus a lot more potential for development. The best bang for your buck would be an RB25DET fitted with RB26 crank, rods, and pistons. This RB26DET would then take some serious bolt on external hardware without complaint.
Personally I would prefer this RB26DET combination to an RB30DET, but it depends on what you want I suppose.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123839
I remember reading some where that if you use the RB20 Pistions and RB26 crank it only strokes out to 2.1-2.2ltrs. Not much at all.
Really by the time you build the RB24 with new pistions etc the price wouldn't work out much different to a RB25.
Only advantage would be insurance and registration issues.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123878
I think they want to do it partly for the novelty factor, but also because when you build an engine like that you have control over bore/stroke ratios, compression etc, and therefore the result can often be better than many of the more common engines around.
I think it is a good idea, but to get the capacity you will need bigger pistons. Good luck with the engine build, keep us updated with the progress, photos etc.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123930
Yeah it is just something different, depends on the price but you may be able to get a motor built for similar costs to an rb25(you would still need the box though) and at least you know the motor would be right and not break in a hurry if its done right.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123976
It is a great engine if you want it to rev out. Lets face it rb20s rev out much higher and better than 25s, by increasing the displacement you have better mid range and the revy top end.
I too have had serious thoughts about it, but unfortunately the RB20 is such a fussy enginem the 25 starts to look like a good investment.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-124018
Originally posted by meggala
ok I have heard of
meggala
what about a 2.8, i've seen a special edition r33 gtst series II with 2.8 litre engine????
I think the r33 is an MR
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-124101
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
