I was reading the new HPI mag and read something about building a 2.4 ltr RB20, it said you use a gtr crank and rods with 4AGZE pistons.
Anyone built/heard of one locally. For the price of a stuffed rb20 it would be as cheap as buying a rb25 probably with something a little different.
https://www.sau.com.au/forums/topic/8478-rb24/
  • Replies 45
Posted Images
ok I have heard of
rb 2.2, = tomei larger pistons only
2.3 bigger pistons 81-81 mm with rb25 crank and rods
2.4 with the tomei pistons and rb26 crank and rods there is machinig requiered but not sure what
2.45 special hks cranks rods etc and dispalyed on my site
do a search on the sdu foums it has been disussed heaps personally I would only do the tomei pistons or copies 82 mm cause I know some one who made around 600 with this combo.
and decided againt the 2.4 kit cause and rb 25/26 was chaeper this was in japan
meggala
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123615
Guest Works Auto
Guys im in the process of building a RB24 for my 32 as yet ive only got the 26 crank and rods havent yet sussed out what im gonna do for pistolas but my mechanic says he has it sorted so we will just have to wait an see what goes.
Im nearly finnished my upright manifolds for the twin TBO's and the 100mm bar n plate core going into my standard GTR cooler along with the custom plenum with 76mm throtle body, GTR injectors, after market rail and GTR pump it should go a bit better than a standard RB20.
Ill post reports and pics as they are available.
Cheers
Ross
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123761
Guest Works Auto
Im sure you have heard of ND4SPD well he is a mate and he is doing the mechanical work as for compression well im an office jockey/salesman so id have to ask him about that so ill let u know.He also seems to think the RB20 pistolas wil fit with the 26rods and crank,.....Cant see it myself but he is the mechanic so i guess he would have a better idea than me. We got a few RB20 blocks and shit around so we will dummy together one before we do it to make sure.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123788
Yeah I heard of him, didn't know he built engines. I would agree with Meggala, that to get the increase in displacement that your after you will need bigger pistons. Luckily the RB20 blocks are relatively cheap so you can do some experimenting.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123804
The main disadvantage, as I see it is the RB20 cylinder head.
You are going to be stuck with this, even after an increase in capacity, it will limit the final power potential.
The RB25 and RB26 have a far better cylinder head design, and thus a lot more potential for development. The best bang for your buck would be an RB25DET fitted with RB26 crank, rods, and pistons. This RB26DET would then take some serious bolt on external hardware without complaint.
Personally I would prefer this RB26DET combination to an RB30DET, but it depends on what you want I suppose.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123839
I remember reading some where that if you use the RB20 Pistions and RB26 crank it only strokes out to 2.1-2.2ltrs. Not much at all.
Really by the time you build the RB24 with new pistions etc the price wouldn't work out much different to a RB25.
Only advantage would be insurance and registration issues.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123878
I think they want to do it partly for the novelty factor, but also because when you build an engine like that you have control over bore/stroke ratios, compression etc, and therefore the result can often be better than many of the more common engines around.
I think it is a good idea, but to get the capacity you will need bigger pistons. Good luck with the engine build, keep us updated with the progress, photos etc.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123930
Yeah it is just something different, depends on the price but you may be able to get a motor built for similar costs to an rb25(you would still need the box though) and at least you know the motor would be right and not break in a hurry if its done right.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-123976
It is a great engine if you want it to rev out. Lets face it rb20s rev out much higher and better than 25s, by increasing the displacement you have better mid range and the revy top end.
I too have had serious thoughts about it, but unfortunately the RB20 is such a fussy enginem the 25 starts to look like a good investment.
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-124018
Originally posted by meggala
ok I have heard of
meggala
what about a 2.8, i've seen a special edition r33 gtst series II with 2.8 litre engine????
I think the r33 is an MR
https://www.sau.com.au/forums/topic/8478-rb24/#findComment-124101
