Skyline33,
The 2.8 litre in an R33 is probably a variant of the HKS 2.8litre stroker kit, while I wouldn't bother on and RB25 the kits do get used alot in high-horsepower cars in Japan. The kit is over $10K, therefore you would have to seriously consider an RB30 style engine at that price.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-124188
  • 4 years later...
  • Replies 45
Posted Images
there is a guy in adelaide who has a rb24det its in a cefiro the motor was sold to huddy from kansia on port rd
the motor made 230rwkw and a shit load of down low cant remember what turbo or injectors but had a remaped ecu and gtr fuel pump
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2839279
personally i see figures like 230, even 280rwkw as a joke for the RB24.
When is someone going to crack the 300-350rwkw mark with an RB24? will it HAVE to be me? (if i eventually go through with it, and don't chose RB30DETT)
I mean, christ, we've seen standard displacement RB20's hit figures like that.... Anyone wanna throw some money at me to build a propper mean RB24 the way it should be done? :P
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840162
yet to see or hear of a single 24 here to crack 300rwkw. Even then it wouldn't be THAT fantastic considering the figures some standard displacement engines are putting out. I think 350rwkw should really be the benchmark for 24's
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840286
Its whatever they want to do with it...its there cars. I wouldnt expect a 350rwkws RB24 to be any quicker then a 280rwkws RB24 until you get to over 180km/h
all depends on the setup of everything else IMO. Would be interesting to see though.
I do understand what you mean about it being their car though. Would be nice to see an "all out" "extreme" RB24, showing what it can REALLY do.
Funding anyone? :)
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840302
I priced a solid lifter conversion with big cams, head work etc etc and all up came out just under the 6k mark. Throw a modded RB26 crank at it with some Eagle rods, $1000 for ARP studs, another $1500 for gaskets and water pump and $1500 for machining and assembly and im not surprised why we dont see many. The you still need to spend money on gearbox, clutch, fuel pump, imjectors, IC, probably a better inlet plenum, turbo, manifold and gate. Its easily a 20k job :)
But you would end up with an engine that would rev harder then any RB26, have reasonable bottom end courtesy of the displacement bump which will allow you to crawl around on the street. But throw a big GT3540 etc at it and it will be interesting to see what power it makes at 9,000rpm :stupid:
But really that wouldnt be the end of it, when throwing an RB25 box at it you may as well throw a close ratio gear set at it as well.
LOL...i have given it lots of thought, and considered all the parts i would need for my little GTSt to try and keep pace with the big power Vic GTR guys...and its simly too much money for the likes of me. Especially when you can get good power out of a std motor.
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840331
Well hey, i manage to drive my twin turbo RB20 around the street just fine. Im sure it'd be fine.
Though i was thinking for a killer 24 setup, maybe using a forged and balanced aftermarket 26 crank, and forged/prepper rods etc. Just to try and get the most out of it.
What ever im going to go ahead with, it will be spaced out over a few years, for affordabilaty's sake. Unless somene throws me a wad of money, or i come by a nice pay rise, or something :).
The full RB24 setup with slightly oversized valves, solid lifters, big cams, ported and polished head etc. Maybe with twin HKS GT28 series turbos. Or if you are feeling adventurous perhaps twin 3040's or 3240's? :stupid:
Seeing i already have the RB26 adaptor plates made up, can just pick up manifolds and turbos off the shelf.
When you actually DO do it though, and you realized what you have achieved, i reckon it'd be worth it :P
Then again, pulling a figure of like 6-700rwkw with an RB30 would be nice too :P (just as a "dyno queen", it won't guarantee fast times :P)
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840341
Yeh, i thought about the HKS 2.8L crank as well. Thought...but you are talking huge money on an engine...where i really think at that point you are not doing yourself any favours. You are better off just throwing it all in an RB26 and having a much better result for all that money spent.
Its all talk anyway, i dont see how you can justify that sort of expense on a motor that isnt beign used in competition.
Rather then go crazy on bottom ends, i would be far more interested in seeing what a std stroke RB20, with 82mm pistons with solid lifters, porting and oversized valves and modded combustion chamber, inlet etc etc
If you are going to beat your chest using an RB20 it has to use the std crank...also makes the build a whole lot cheaper...relatively :)
Like i said, i have thought about it a lot...and have almost got all the parts for my cheater RB20...mine is on a strict budget which means i have taken some shortcuts and cheated :stupid:
..i will add. A 240-260rwkws RB20 is bery nice to drive on the street. Its quiet and easy to cruise in. I imagine with more power it would only be easier to drive as the power band moves up the rev range. Its when you are off the road and you can use the revs and drive at speeds to enjoy them that they become challenging to drive :P
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840356
"personally i see figures like 230, even 280rwkw as a joke for the RB24.
When is someone going to crack the 300-350rwkw mark with an RB24? will it HAVE to be me? (if i eventually go through with it, and don't chose RB30DETT)"
Errr your joking right 32 gtst imported by my work 2.4 + T88 = 405rwkw
all in a package that looked like a stocker from the outside
and 355rwkw at a SA SAU dyno day so its already been done a proven
japs build tough cars the end
Im sure Huddys package would make alot of grunt to if he put a bigger turbo on than the 2530
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840370
Im pretty sure somewhere up there i said im "yet to see"
Now that i have "seen", then i stand corrected :)
Anyway, would a 2.8L crank even fit? Wouldn't that give a different end result?
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2840382
I've been toying with the idea of a "cheater" rb20 too...and i'm leaning towards getting the 82mm tomei pistons...can someone tell me whats the maximum piston size we can use for a rb20 block? Can 4a-gze pistons can be used with the standard crank? and if so what work needs to be done to use them?
I'm not keen on the idea of stroking it as i want to keep the short stroke of the rb20 so i'm just looking at boring the block out...
https://www.sau.com.au/forums/topic/8478-rb24/page/2/#findComment-2841035
  • 3 weeks later...
  • 2 months later...
    • Really, anyone modifying a car isn't being financially smart. We're doing it for the things we love. And honestly, a high revving, light, NA car is actually pretty darn fun. I used to have a Swift Sport, and I miss that thing as a daily, and yes, doing something like some intake and exhaust stuff would have made minimal gains, but would have bought an even bigger smile
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to motorsport@sauvic.com.au or print and hand in and Driver Sign In. email motorsport@sauvic.com.au To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email motorsport@sauvic.com.au Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6. Tony 7. Alix 8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
    • Yeah, playing with naturally aspirated is not smart bang for your buck power wise, but then I've never been known for being smart when it comes to cars and modifications
    • I mean from V8 world there are gains to be made in intakes and such over stock items, but definitely only if you tune them. We're talking about I dunno, 10kw here and there on a 300KW v8, gains made by tuning in the 0.2 AFR that it changes so YES but also no you won't notice it other than the sound. Duct the air as mentioned 750,000 times and you will notice happier IAT's which definitely make a difference N/A. I mean my unsubstantiated guess is you'd go from 140kw with everything stock (after cams) to 145kw with everything and a tune :p
    • I decided to "spend baby spend", and "risk it for the biscuit" 2 Orders were made buying parts that I "don't really need but really really want" totalling $2.5k AUD 1: In stock items (intake plenum and throttle body) 2: The airbox thingie, with no real ETA for them getting more stock, so patience will be required
