Hi Guys, after alot of searching i can't seem to find much info on drag times for the auto guys.
Can we have a post from those who have ran there cars ..... i've done abit of work on my car now and its certainly slower than the manual boys.... so i need some auto guys to compare with , as i just feel somethings not right.
Heres my cars specs
S1 R33 sedan Auto
Std turbo
LINK plug in (i tuned it on DYNOLOG so power reads lower dont forget)
145 rwkws (stock auto gets about 110 on these.)
boost 11.5 psi, turning it down to 9 psi to keep wastegate open (more just rolls power off earlier ...... ahh the joys of free dyno sessions)
No AFM
pod (no CAI) factory airbox and modified GTR snorkel coming
MV auto shift kit
Iridiums .8mm gap (borrowed 32 GTR coils as mine died) Splitfires on there way
New rear 255 tyres , gripping well
R34 GTT cooler
3" dump , 4" magic cat, Tanabe jasma catback
Now best i ran last week was a 14.53 @ 95.3
Last night i ran a 14.32 @ 98.6 (iridums, shiftkit, gtr coils)
I think time was more so from me manually shifting .......auto shifts at 6100 every time, but this makes revs drop to 4200 and it bogs a tad.. so reving higher while falling off the power a little makes shifts higher and not bog.
So, im perplexed, what do you guys get
Also in my readings last night i saw one guy post that the fast software shows 4 different part numbers for the auto turbo ?.... maybe i have a small one !( turbo haha)
Gary
https://www.sau.com.au/forums/topic/84791-drag-times-for-auto-r33s/
Cmon someone must have some drag results and what they have done...
SydneyKid, have you any input on the FAST software mentioning 4 different part nums for the auto 33's ? I guess if so its possible there isnt just S1 & S2 33 turbos .....
I've got a few other pecularities i've noticed i'll share if someone posts up.
there are a couple of R33 autos up here that i know have got 13.5-14.0s... with the usual stage1 mods..
You'd probably want around 12psi on R33 turbo to get the power up, and your times down as well. Above that you probably won't see much power difference, but 9psi I would say is probably a little low for R33 to be optimal.
What is your 60' time?
Yeah but as i mentioned power didnt drop off as much when i rolled the boost back... i tried alot of things but there just wasnt any more in it...
60' 's best was 2.4
One thing i really notice is that you floor it, boost builds to 11 psi buy mid 2000's but there is nothing until just on 3000 , then whoosh , its off....
I tried moving the cam on point in the link, to above and below 3000, below does nothing, at 4000 it give a kick at 3000, and then another at 4000..... but still the initial delay..... anyone else notice that...
and yes i've checked timing in that area, even adding alot of timing while its 2500-3000 and the boost is up does stuff all.....
4door sleeper,    but what have you done to your though ??
Normal mods - 3 inch exhaust (turbo back), intercooler, pod filter in a custom cold air box, GCG hi-flow turbo, power FC, fuel pump and the MV Automatics shift kit.
Edited by 4door_Sleeper
Ah, ok the GCG highflow would help.
I've got a Vg30 turbo on the way , and i already have a t04 vtrim and mazda comp housing to suit from the rx-7's previous incarnation highflow.
So hopefully with that together i might be able to scrape 12's .
What 60's were you getting ? Mine were 2.4
Gary
My 60's were 2.08 or something like that with stock turbo but 2.2 with highflow.  Went from 13.8 to 13.5.  This is an auto R34.
Thanks Abo Bob,
Thats a bloddy good 60'. Were you stalling off the line or just stabbing it . ? whats a 34 stall to factory, and is yours factory ?
Are you saying you only went from 13.8 to 13.5 with the adition of the highflow ? wouldn't you be expecting more .... obviously you lost .2 off the line.... still.
How did the mph difer ?
Trying to stall mine us was the worst launch of all..... was best to just stab it full, ease off (turbo seems to spool quicker when throttle 1/4 open or there abouts), then full again.
  • 3 months later...
Just an update to what turned out to be a problem.
The drama of the car hitting boost but not going hard until 3000 rpm was actually a fault.
The fuel pump switching was causing it, fuel pressure barely stayed at 40 psi when boost got to 10 psi... then at 3000 rpm, it jumped up to 50 odd and away you went.
So for now i wired it on permanent, until i get around to installing a new pump.
Responce is ALOT better off the line now. I'll head out to the drags soon for an update, hopefully into the 13's.
Gary.
got a 14.7 cou[le of weeks ago
only got minor mods
3" x force exhaust high flow cat
safc2
split pulse dump pipe
standard intercooler
10.5psi on stock turbo
215rwhp
tryied to do tune up but not producing anymore power, think the standard intercooler has caused a restriction. will replace soon
4door how much effort was required to get the PowerFC tuned for auto?
I had no problems, just put it in and tuned it (same as a manual) Others have said they have had problems, but I didnt. Its definatly worth trying, especially if you can return the PFC afterwards (if it gives you trouble)
i don't have a r33 have got a r32 but i am just wondering how do you stall the auto's up i never seem to be able to get mine to do it. Best i couild manage was 2000 and that was after very very slowly stalling it up 500rpm at a time. Which would kind leave me sitting on the line at the drag. Also would a shift kit help make stalling it up a bit easier.
probably more important than power and turbo's etc is how does it launch. how are you taking off, does it bog down, does it wheelspin, does it feel sluggish at the launch stage? no point adding more boost and a big turbo if the launch is average as.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
