Hey guys and girls I just got a 3037 pro s on my rb25 with all the other bolt on's included, just wondering if anyone else runs this turbo and what kind on power they make. My internals have also been done. (pistons,rods etc etc.)
is the 3037 pro s straight bolt on....?
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1537240
is there any difference between the externaly gated and the pro s (internally) in terms on ps rating, also what other mods did steve do to his rb25 to make 320rwkw and was it on pump fuel?? if so im looking very forward to my dyno run in a few weeks. if pos could you get me all the mods that steve did to his rb25 so i can compare it with mine, that would be great if you could. did he have stanard internals or forged ect ect. It was in a r33 i figure i've done the conversion into my r32, counting down the days untill its back on the road, lost my lisence for 12 months only got two and a half to go given me plenty of time to go sick on my beast.
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1543242
Steve dropped the comp ratio to around 8.6:1 via a thicker head gasket and had a set of cams. He also stepped up to the .87 turbine housing as the .69 was too small and had power coming on too hard.
With the smaller turbine housing it made 250rwkw I think it was on 15psi. I remember he said it was fun but dangerous squeezing the throttle in fourth at 100km/h and having the car lane change by its self. :mellow:
I remember he used 22psi or there abouts, he had issues with not making the power it should have made, it came down to the exhaust was no good.
Do a search the thread should be lingering somewhere.
Edited by Cubes
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1543251
With the smaller turbine housing it made 250rwkw I think it was on 15psi. I remember he said it was fun but dangerous squeezing the throttle in fourth at 100km/h and having the car lane change by its self. :D
hehehe I am scared now.
I have a R33 Series II 96', and I just got a GT30 with a VG30 ass end on it (which is a .63)
so yeah... maybe I should sell it before I wrap it around a tree?
What ECU was he running?
oh, and my car just got compression tested - 169 accross all cylinders.. So the motor will be in pristine condition for this nice big turbo...
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1543771
Both turbos are rated for 480ps and could possibly produce simliar numbers but you would tend to think the internal gated turbo would be restricted by the flow of the tiny wastegate (compared to the bigger external gate). Response and the delivery of the power would be the biggest difference between the 2, plus the extra flow of the external gate, would make the 3037S be the more popular in my mind.
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1543927
Is that a garret turbo your using?
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1543935
Its a HKS turbo where its had the 45MM internal gate designed for the purpose. It will be fine, the reason people step up to external gate with larger turbos is because the 'usual' internal gates cannot pass enough exhaust gas causeing boost creep. Boost creep where you cannot keep boost down, it keeps building. You often see this with a bad highflow.
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1544001
Thanks on the info mate im runing same cams and same ecu, do ya think the g-ready plenum will make much difference? I cant belive that he was sqweezing the throtle in 4rth and it steped out thats fu#@en hardcore. which turbo housing would have mine come with do you know???
Ans also what exaust was he running that was no good because im just about to change mine because in having similar problems. What one did he put on.
Edited by mait32
https://www.sau.com.au/forums/topic/84840-hks-3037-pro-s/#findComment-1544201
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
