hey guys,
after blowing my standard turbo, i picked up a modified garret t04 and a few other bits and pieces...
my problem comes in the way of the oil feed banjo connection to the turbo... the original bolt has a 12mm thread diameter, however the turbo has a 10mm thread diameter...
has anyone else encountered this?? what did you do?? what are my options??
anyone know where i can get a line other than horsepower in a box?? im not sure if there lines have the different thread.
cheers
Linton
yeh take your line to enzed or pirtek and say hey this is a problem...fix it! For a price they will, normally not too bad and they do a good job. Might make you up a stainless line with the banjo fitting for block and the right size banjo fitting or other for turbo.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
