hi,
i have my nissan r33 gts-t skyline its time to see it go this is a eyecatching skyline but also has the power to go with it the car atm has 300rwkw and with a few lil extras (which will be done shortley) will be making more.
iNissan R33 Skyline gts-t
Black
400r body kit
18 deep dish implus rims
front recaro race seats
Front mount intercooler
Blitz boost gauge
T70 turbo
50mm external waste gate
z32 air flow meter
Malpassi risen rate fuel pressure reg
Bosch 044 motor sport fuel pump
Full hks exhaughst
Custom piping and custom dump pipe
Custom plenum chamber
Oil catch can
Surge tank (not yet fitted)
Cusco strut bar
Front seat harnesses
Sparco gauges oil and volts
Auto meter air/ fuel gauge
Tinted windows
Front bumper resprayed
111,000
All mods done within 1,000 ago
Extreme heavy duty clutch
Black widow s/steering wheel
Nismo gear knob
All new gear boot and hand break boot made
Custom dash and door inserts
car has being lowered
plates not included
Clarion head unit
7" roof mount tv
built in dash tv
ps2
2 10" subs in box
Clarion front and rear splits
Alpine v 12 amp
With 10mnths Rego
Im after swap with cash
Will not be disappointed
This is a neg
car has being lowered and a turbo blanket is on it also a new set of spitfires on the car also has a new sealed battery
$26,000
make me a offer all considered
this will come with a rwc
Edited by teazn_r33
https://www.sau.com.au/forums/topic/84869-r33-for-sale-or-swap/
  • Replies 72
Posted Images
i have over 38,000 dollars in recipts for this car i need to sell this only for the reason it it not practial as i am in the music industry and if anyone here can carry pa speakers in this car let me know lol this car hasnt seen a day at the track or drags pm me if intresed at all open to any offers or swaps
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
