Well it was better wasn't it... and proabbly with a different tuen it'll get better. How did it sound?
your right about the tune , but i wont be bothering for a while now . you see i hurt the motor . now smokey at high revs and using oil .How did it sound ? Wish i had taped it , it sounded great , nothing like the sound of a twin cam at full song , lots of induction roar and the open extractors screamin , luv it .
As for the engine , i have another rb30 block which i will freshen up and put under it .
  • Replies 72
Posted Images
that sucks that your car has broken. im building the same motor. anyway that i can get some specs of what parts you used and the cost to get the head modifyd to fit the block?
*edit* i just found your old thred with the specs of what you did. good work. im gona probly be spending 800-1000 on my head tidying it up and replacing bent valves and getting the vvt set up to work
did you get the chance to dyno it?
thanks, and good luck with fixing it
Edited by BADR33
UM I not too sure whats goin on with the engine . its not using oil , even tho it has smoked a couple of time at high revs . in fact the oil level has stayed constant in last 500 km since it last smoked . also one of the breather hoses isnt hooked up .
maybe i was being bit of an alarmist ,
this weekend am going to do a compression test .
apart from all that it seems to be going as strong as ever .
oh yeah did i tell you that i bought another skyline .
well it was cheap a 5 speed series 3 r31 WAGON , ( yeah go the wagons ) and its powder blue , nice boy colour lol
damn!!!
i wish i could find ones like that
all the ones that i see for sale are auto's and heaps of sh!t
how cheap was cheap???
$950 and has perfect body and interior , would you believe i havent seen it yet . bought it off ebay in NSW , friends down there checked it out for me. its coming up on a transporter next week .
Edited by dondesoto
Woah dude that looks very clean, especially the engine. What are your plans for this car?
As the body of my red wagon is reaching its use by date , will transfer the good gear across to the " NEW " blue one . It will be a sleeper , keeping it absolutely stock on the exterior , standard wheels suspension and ride hieght . Should even keep the standard hubcaps on .
  • 4 weeks later...
you should HPC coat those extractors, get heat wrap, wrap them and after that make up a stainless heatsheild  :D
this will give you the coolest intake temps possible  :O
YEP GOOD IDEA , will probly wrap them
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
