Hey Guys,
I searched and didn't find what I needed ,please link me if this exists already.
I am just trying to find out what sort of suspension the r32 gtst has. Then I want to understand all the bits in there (pics most likely needed)
Baiscally I have to try and work out an issue, and I don't know the names of parts, So it would be good to actually be able to ask on here about certain parts instead of "that thing in that place"
I never ended up fixing the camber issues I planned to cause I ran out of money, but perhaps now I may need to replace bushes anyways.
This is the thread with my problem if you wish to check it out/help
http://www.skylinesaustralia.com/forums/in...dpost&p=1537049
Cheers
Chris
https://www.sau.com.au/forums/topic/84900-help-an-idiot/
Ok, I can move the shaft that runs from the Diff to the wheel. I can move it in/out of the wheel/diff about 3mm The left hand side is solid as. Would this be the problem? Any ideas how to fix it?
Maybe I am completely wrong, but that seems to be your problem right there. If you've been drifting, it seems that your diff is shagged, causing one of the axels to slide in and out of the centre. You shouldn't be able to move the half shafts in or out I don't think...
Its also possible your hicas rack ends are stuffed, causing random toe in and out at speed. What condition are they in?
https://www.sau.com.au/forums/topic/84900-help-an-idiot/#findComment-1537343
Thanks Predator, but Can I suggest that if you are going to reply to ideas to fix my problem that you put it in the other thread to keep it tidy please? Just keep this thread for the question asked - ie. suspension components,
That said, don't think I dont appreciate the help :D To answer you question- I will be checking out the HICAS, however the problem is that I don't know what to look for...I will look, probably tommorow night, and see if I can tell, but since I dont know what a working one looks like...I may not know what a non-working one looks like
Seems like I will have to learn about HICAS and diffs while I am at it!
Cheers
Chris
https://www.sau.com.au/forums/topic/84900-help-an-idiot/#findComment-1537385
