I find that just watching where others are braking, and what line they are taking (both good and bad) can greatly help your technique.
Tyres will make a massive difference, depending on what you have on there.
The higher friction pads on the front are a good idea - is there any other way to change the brake bias on the R33?
I remember whenever I drove the UQ FSAE the car felt best to me when I dialed in a lot of front brake bias - probably be a good thing to try on the skyline. Probably an indication of my driving style as well.
The tyres I was running were falcon ziex 326 that were just touching the wear pattern on the front (3-4mm rear), so they are about as crap as you can get. I'm in the market for a good set of tyres at the moment.
I'm not sure about the september sprint day, I'm heading overseas for a holiday in a couple of months so I'm trying to limit the cash I'm spending right now.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
