On my RB25, this is my boost curve
2200rpm = 6.5psi
2600rpm = 11.6psi
3000rpm = 15.8psi
3400rpm = 17.3psi
3800rpm = 17.9psi
4200rpm = 18.7psi
4600rpm = 19.1psi
5000rpm = 18.5psi
5400rpm = 17.4psi
5800rpm = 15.8psi
6200rpm = 13.8psi
Edited by Robo's
On the dyno a Rb20DET with a gt2530 generally makes 1.1bar around 4k. On the street obviously it will be a little later, say rolling on in second gear may have the car start pulling hard from 4500rpm.
Edited by Cubes
I've put in an order for a gt2530 for my rb20.
I was expecting the gt2530 would be a little more responsive than that.
What rpm does it start to build?
surely it makes SOME boost before 2800, even a couple of psi?  Its also gonna depend hugely on your tune and boost control method.  At the end of the day it is an rb20! not exactly known for their super response and early boosting!
well i have a TD06 on my rb20 and set at 1bar it starts to spool at about 3800rpm and holds till around 8700rpm
Once i get it tuned will let you know progress with it.
Cheers B
8700rpm?? And it needs a tune? Sheezus. What valve train components and cams are you using? Mine makes max power at ~6100rpm and limiter is set to 7K.
Robo's is making 6psi at around 2200rpm with an RB25 which is 25% larger in capacity than an RB20 so its gonna spool the same turbo 25% earlier so I guess 2800rpm is around the mark.
Thanks guys it seems mines fine then I may still need to get the spring checked as it seems to hesitate at .5 bar before continuing on to .7 bar I fitted up my Walbro last night it seemed to make the power come on a little more smoothly feels like it's making 170 rwkw ish it feels easily as quick as my old 180 did (which made 169 and its a heavier car I think I may need to get my cooler put on asap rather than waiting till next pay day though as Im a little worried that it feel's so quick
Well i have not yet finished with the car and the Power FC is about to go in so thats why i say i need a tune.
My ride:
1990 R32 GTS-t
RB20
Car mods as follows:
TD-06 turbo with external waste gate
550cc GTR injectors (with extra injector for high boost)
GReddy injector equaliser control (for extra injector set up)
GReddy electronic boost controller
GReddy turbo timer
upgraded fuel pump and swirl pot
adjustable fuel regulator
Z32 AFM
Hybrid FMIC
GReddy oil cooler and relocation kit
3' dump from the turbo into rear muffler which is standard at the moment, with extractors.
GTR rotors with green stuff pads.
irridium plugs
rods and pistons have been done as well as bearings (is what i was told) and a set of HKS cams
set of race springs with stock shockies (soon to be replaced)
Apexi air intake with modded CAI /Heat shielding (thanks to SAU thread)
button racing clutch and locked diff (thing of changing diff)
Mods to come:
front and rear strut brace (looking for a Cusco BT front)
new seats (as the BRIDE drivers seat is a carbon race seat with not much room)
new steering wheel (again for some extra room)
new gear knob (as the old one is pretty crummy and slips)
and maybe work on a new suspesion set up. (want coil overs)
Other than that its pretty much a stocker in the looks department ;)
So ~4000rpm for what ever boost you dial in to it sounds about right then. It kicks hard you look down and notice the tacho on 4500rpm swinging towards 7000rpm. :D
Yeah i know that feeling well ;)
  • 3 weeks later...
hmm well i've DEFINITELY got a problem... :P
got a hks 2530 - fmic/zorst/pump/ standard comp with hks fcd... it max'd power at 225rwkw 'conservatively' on 14psi...which is good right...YES.
BUT
...now that i drive it, its not making f*k all boost and LAGGGGGGGY as all the way until around 5000rpm... can say i'm very disappointed and hope its a fixable problem...
possible probs i thought of was - collapsing intake pipe to turbo / faulty boost controller (turbosmart dual stage fairly old) / maybe its not even standard computer...
just spewing coz its got absolutely NO midrange... heaps spewing...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
