Hey, since i'm soon to be a skyline owner, i was just wondering roughly how much it would cost me to get my skyline up to 200rwkw and what would be the best and cheapest mods to get.
The skyline will be pretty much stock, except maybe for a pod air filter and catback exhaust. There may be other mods, but im not sure yet.
I want it to be able to beat my friends Holden V8 Commodore (Damn Commodores!) which has 197rwkw :D
Also my other friend is buying a Mildly modded VL commodore with an RB30DET engine in it, does anyone know how much power this car would have?
Edited by Chainfire
https://www.sau.com.au/forums/topic/84961-how-much-for-200rwkw/
bro i own a 97 M-spec. my goal is 200kw @ the wheels befor dec.
to pull about 180wk @ the wheels you will need a good cat-back exhaust system, a front mount cooter, boost controller and a aftermarket computer to get the best from ur stocky turbo.
wind up the boost to around 0.9 bar (1 bar = 14.5psi if my merrory is right)
If you want up to 240kw @ the wheels, add a good bolt on turbo, larger injectors, larger fule pump high flow cat and adjustabul cam gears. wind it up to 1.2 bar of boost. i been told it sould give you better turbo responce and stronger mid range.
hope this info helps ya mate. good luck wit it bro.
Just remember modifyin ur SKYLINE is like gettin hooked on drugs.... its so addictive... ;)
yah i bet it is ;) i have never driven a car faster than my friends V6 statesman, which isnt that fast :D so even a stock skyline would have me addicted :)
My plans for first mods are, Turbo back exhaust, cold air intake, Boost controller, aftermarket ECU, and a good tune. Pretty much as above in Dush's post, minus the intercooler, plus a cold air intake.
So could anyone tell me what these mods would cost all up, and if they'd bring me to 200rwkw? or atleast close to it..
I found these figures for mods on a webpage, can anyone tell me if they are accurate?
Cold Air Intake: 15rwkw
Exhaust: 20rwkw
Boost controller: 15rwkw
ECU: atleast 20rwkw
Assuming the stock skyline has between 130 - 140rwkw, these mods would bring the total to approx. 200 - 210 rwkw?
i'm looking at spending $3000 maximium for my first mods, hopefully that will be enough to get me what i need for 200rwkw.
There is no hard and fast rwkw for any mod. That website is stupid.
You also need to learn that not every mod is done to increase power, there are many mods that need to be done as support mods to allow the extra power from other mods. ie fuel pump as a good example.
and exhaust and power FC will take u close to $3,000 ;)
Required:
Full Turbo back 3" exhaust - ~$1200
K&N Panel Filter - ~$100
AVCR-R (or other boost controller) - ~$550
PowerFC+HC + Tuning - ~$1500
Adjustable exhaust cam gear - ~$200
FMIC - ~$1200
= ~$4,750
Possibly required:
Larger fuel pump - ~$300
Fuel regulator - ~$200
Edited by benm
NJR R34GTT yes.. i realise you need those sorts of mods to accomodate for the extra power, but would you really need an aftermarket fuel pump or better intercooler just for 200rwkw?
Shanef I would probably not have to pay to have any of the above mods installed, as i would probably do them myself, and also have friends that are, or were mechanics... and that much for a tune?? u serious?!
A good exhaust, i have been quoted to be around $900 by a few people PowerFC ECU - $1000 give or take
Cold air intake - $200 though the skyline may already have one installed..
Boost controller - dunno? but it can't be that much?..
I know the skyline will already have a catback exhaust installed, is this different from turbo back? if so.. how? better, or worse..
So if i am correct with the prices then,
Exhaust: $1000 approx
PowerFC: $1000 which i have seen for this price
Cold air intake: $200 approx
Boost controller: $500 give or take? (coz i have no clue how much these are)
Total - $2700 approx. without tune included, if a tune makes a great difference, then i have no probs spending a bit extra for it.
I really can't see where the extra cost is... my guesstimate of $3000 seems pretty accurate... yet shanef finds it laughable ;)
Maybe i am getting bad quotes.. i dunno, does anyone who disagree's with these prices mind telling me what they paid?
You'll need the intercooler when you start playing with the boost controller ;)
also.. if your JUST looking for like 200kw as cheap as possible, you could get a safc2 for like $400 (save $600 from not buying the powerfc)
get a bleed valve for like $22 instead of a boost controller (saved $478 from not buying an electronic one just yet )
thus with the $1078 you've saved you can buy a nice intercooler :D
oh btw.. a powerfc will be like $500-700 or so to tune
Edited by justin911
cool, thx for the info.. keep it coming :P hey, i just saw a brand new Power FC for sale on ebay to suite RB25det for $650AUD perhaps buying the parts from ebay would be the way to go... i will see what else i can find.
This is what I did to get 200+ rwkw (9.5psi).
Power fc - $960
AVCR - $600
Hybrid front mount - $900
3" exhaust - $1000
Power intake filter - $150
Labour - $250
Tune (required with power fc) - $400
Total - $4260
If youve already got a filter and exhaust then take away approx. $1200.
You're probably looking at around $3K all up.
I reckon your estimate is pretty close to the mark.
Eventually you will probably need to upgrade your fuel pump and regulator as the stocker will be struggling a bit on high boost.
Fuel pump - $400
Fuel reg - $170
Edited by gR33ddy
cold air intake.. aint that whats the stock cooler or aftermarket cooler is for..?
Cold air intake basically means shielding your pod filter from the hot engine bay temps. This means that your charge air will be cooler even before it hits the intercooler. It will only make a small difference, but a difference none the less.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
