Hey mate, im keen as for that air filter, i live on the northside of brissy, Narangba, 30min out of brissy, where are you? hope u still got it or have u sold it? does it screw straight on to inlet pipe or does it need a reducer or enlarger on thje pipe?
hope to hear back from ya
https://www.sau.com.au/forums/topic/84963-blitz-air-filter/#findComment-1545035
