hi nismo 400....it makes absolutely no diffrence what brand you use as to wether the colour is right as a good painter will adjust the colour anyway....i say this as there would most likely have been old repairs on the car or the paint could be faded aged ect.....therefore the colour would need to be tuned up....and just for the recod...the factory use a hi bake system were as all panel shops use low bake....hi bake paint will not cure unless used in a hi bake set up
  • Replies 74
nismo400,
like ylwgtr2 said it doesen't really matter what brand you use. some manufacturers have alternate chips for some colors where there is a known variance of shading from the factory, some colors actually have up to 6 variatons of the parent color code, but any reputable paint supplier should be able to come up with a "to the naked eye" perfect match.
even if they can't there are clears available that can trick the eye using light refraction to hide repairs that may be a shade or so out.
90% of all repairs & touch ups are using materials that are not what the factory used to paint the car anyway. Factory or OEM products (original Equipment Manufacturers) are different to the aftermarket crash repair coatings anyway. most vehicle manufacturers use baths for primer & Positive/negative charges to get a uniform micron build of primer on a production line. then most these days are using Waterborne technology (yes waterbased) top coats, these unlike our well known 2K, COB's & acrylics require large volumes of airflow to cure, not baked in an oven as we commkonly see. Although i am told that some repair shops in Australia are now set up for this waterborne (Aquabase) technology.
thevilworld, KR4 has a metalic flake, so your options are Acrylic or COB. Acrylic is old technology, needs lots of coats to get coverage & uses a 1K Clear over metalics, it's needs to have the C ra p buffed out of it & will loose shine quickly. if you can afford to, stay away from it!
COB (Clear Over Base) is a modified acrylic, much better coverage & color matchability & uses a 2K (2 Pack) clear over the top. a good painter will get a shine straight off the gun, no need for buffing & the coating will be durable & last for years..................Go COB, for the extra cost it is a far better prospect!
find a reputable repairer & talk to them.
nismo400,
do they still make acrylic?:D as far as aquabase goes there is nothing special with it as all it is is the base coat thats waterbase....its been out for quite some time and there was lots of hype when it first came out ...but its really not that great....same booth and equipment/drying times ect...and i think you guys will find that 1lt of COB basecoat wouldnt be that far off the cost of acrylic anyway....its just that with acrylic you put acrylic clear over it and COB basecoat requires 2K and thats where the cost diffrence will be....and just to clarify for those that dont know....all mettalic colours require clear....acrylic or COB Base coat
oh and i would strongly disagree with the coverage comment....COB covers shithouse...i always use colour build primer and put a ground coat down for metallic's...altho my main traffic these days is motorcycle colours which this is mandatory as they are candie's and translucent colours....big headache!
Totally agree with the ground coats, tinted primers & value shade primers.
but acrylic laquer is Henry Ford technology & there is no reason to use "Old" technology these days.
hi-build, LE (low Emmission) products are the way to go. (2K, COB & PU)
Then of course there are COB's & there are COB's, we have 2 on our system, same brand, different pricing, different qualities & coverage to suit different markets.
try & get a "warranty repairer status" using acrylic................it just won't happen, they won't go near you with acrylic.
I wouldn't let anyone near my pride & joy with Acrylic (my own personal oppinion of course)
If you want acrylic, go & buy a rattle can from the Hardware shop!
Hi guys.
i want to get my rocker covers painted in the same colour as my car.
Will the same paint work under the bonnet because the rocker covers are exposed to a degree of heat or do i have to take it to some professional?
2k or COB 2 k is fine for valve covers
I've got KH2 K on my plate
The KH2 is gunmetal grey, (which i figured looking at paint) .. But does the extra "K" two spaces after it on same line mean anything extra ???
Thanks for help
Gary
  • 2 months later...
  • 1 month later...
KL0 - Spark Silver Metallic
hey, is this the stock silver for a 1996 series 2 r33?, does have matallic in it. just about to respray, anyone know? thanx
Sure Does, plenty in fact................go Clear over Base (color & 2K Clear) :)
  • 4 weeks later...
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
