I reckon wait til you see a speed camera up ahead... Then stab the gas a bit and then just back off again. Let him be a hero and get caught speeding.... Then you can roll back past laughing....
Just watch he is not a crazy before laughing...
https://www.sau.com.au/forums/topic/84976-how-do-u-do-it/#findComment-1538511
look down to ur trusty electronic boost controller, dial in 1.1 bar or 200rwkw then 3rd gear and cya later, this is in a controlled environment of course, on the street, grab the nearest piece of fruit and throw it at him
Its a stock standard 33 mate...
I wouldnt bother racing him, its a commodore anyway youve got nothing to gain by winning and youll look dumb for losing
https://www.sau.com.au/forums/topic/84976-how-do-u-do-it/#findComment-1544288
beating a skyline in a commodore is just like the special olympics...even if you win you're still retarted...
https://www.sau.com.au/forums/topic/84976-how-do-u-do-it/#findComment-1544472
I usually just ignore them and wonder how long till they get busted or hit a pole....
Dont be rude unless you know you can get away with it... LOL
Hi col,a boegzz down the road.Has a what sounds to be a fairly worked commodore,has regular fights with the missus @3:00am,does burnouts whenever he feels like it, came home about 4:00am the other day on the back of a tilt tray with the nose allmost to the windscreen.
Sometimes you cant tell em.They have to learn the hard way.again and again and again. :blink:
https://www.sau.com.au/forums/topic/84976-how-do-u-do-it/#findComment-1545079
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
