Originally posted by JiMb0
This is just too f**king ridiculous ... I want to go get my mods engineered but now I'm too scared to even take the car on the road to the engineers workshop incase I get defected on the way there !
LOL
and the paranoia sets in. i'm engineering mine soon. let's do it together.
...umm, actually, do your mods first and then engineer yours.
  • Replies 49
the rta has a list of certified engineers. you should only get it done at those engineers as the epa might not honour a non cetified engineers certificate. can't find the url at the moment. will look for it tonight. i know it's in one of the threads in here already. just search on 'engineers' and you should be able to find it.
Morgs: when re'regoing your car the inspection station only checks things like tyres, lights, horn not bovs or big turbos etc.
400HP: My engineer can do bovs
The car came with one standard..... yes technically the factory one isnt a venting model but itll do
guys I found the list of engineering signatories and some other information
if you go the the RTA Website and then go to "Registration" -> "Vehicle Standards" -> "Information sheets" theres a PDF called vsi15.pdf.
This link may take you straight there -
RTA Docs
Jimbo: the way i see it is that you will have no chances of clearing up a defect even if the cop WAS wrong! They issue you with a defect notice, then you have to go clear it up at the rta.
a) the cop gives you an on the spot $70 fine per defect (i believe at this point you lose your 2 points too?)
B) you go to the rta and pay a further $30 to have the car inspected
Now if the cop gave you a incorrect defect, how do you prove it was incorrect and you didn't just fix the problem before goin to the RTA? The whole thing reeks of shit! I would only accept a defect and a loss of 2 points if the rta and epa were present at a defect station.....NOT just some pig taking a power trip!:cuss:
ok for all you people out there worryed about loosing points
you CAN loose points sterio exhust
not for lowered stuff like that if you do turn over the infrigment notice on the back it will say do you want to have this heard about in court you tick yes and send it away that is all you can do as of jul 1st
but you wont loose points for big turbos bov stuff like that unless the cop stuffs up
that is why there is a thing on the back of the notice
dont ask but that is what happens i know
Originally posted by gtssky
you CAN loose points sterio exhust not for lowered stuff like that
This is the issue though. What if you exhaust is right on the limit, or just under. You get defected because this cop has spectacular hearing and knows presicely what dB are being produced. You lose 2 points and $70 ... you don't touch it or alter it in any way, go to the RTA get it cleared ... thats now 2 points and $100 for an exhaust that was never over the limits in the first place ....
How is this in any way a fair system ?
and who foots the bill for the test if it comes back under the guidelines ? I don't see why citizens who abide by the rules should have to pay to prove that a member of the police force can't judge an exhausts dB with their ears ..
I'm all for the police doing their job, but I know far too many people who joined the force just to get their own back ! I'm more than happy to get a defect if I am over the dB limit, or my car is too low, or I'm running an atmo venting bov .... but I'd like the law to operate in the same way it does in other cases where one is guilty until PROVEN innocent ... This whole dealio where police only need to think something is defectable is rubbish ...
Assumption is the mother of all f**k ups, is it not ?
There are no ADR's that say things such as "big turbos are not permitted" and "no BOV's permitted"... the ADR's say stuff like "you are not permitted to alter the emissions of the car by alteration of exhaust and intake systems" or something similar.
In this way I think if you change to any non-standard items in the intake or exhaust part you are effectively changing the emissions. Turbos, BOV's, exhaust etc are all parts of the intake and exhaust and will change the emissions.... this is where it is grey...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
