I had my powersteering pump replaced recently and I still notice my steering goes really heavy whenever the revs are right down. I suspect the alternator is packing it in. I intend to measure the voltage as soon as my car is running again, however I was wondering how hard these things are to install and what choices in alternator there are for an R32 RB26dett? Any help would be appreciated :).
damn R32s.. !
https://www.sau.com.au/forums/topic/85001-r32-gtr-alternator/
First off, check that all the connections on the back of the alterator are correct, particularly the plugs.
As with anything on a Skyline, it will require the removal of much more than the component of interest to achieve the desired result.
It's probably because the engine isn't turning the pump as fast at idle and so the steering becomes a bit heavier. There should be a fast idle switch that kicks up the revs by about 2-300rpm when you turn the wheel at idle.
Im with dave, The altenator shouldn't have anything to do with your power steering getting heavy..... I mean the P/S pump is mechanical right?
In the commodores they have a bypass valve that would sometimes get stuck open and the car would think your driving along the highway so it would keep the P/S heavy.
Cheers
Sumo
Ok thanks a lot guys, will have a look. The car was running perfectly yesterday (just put an 044 in) until about an hour of driving, then the steering got really heavy to the point of not having power steering (big deep sigh). Anyway after it had cooled down the powersteering was back to perfect... this doesn't bode well.. bloody 32s! :)
  • 1 year later...
Ok thanks a lot guys, will have a look. The car was running perfectly yesterday (just put an 044 in) until about an hour of driving, then the steering got really heavy to the point of not having power steering (big deep sigh). Anyway after it had cooled down the powersteering was back to perfect... this doesn't bode well.. bloody 32s! smile.gif
Just my 2c on this...
I took my car in to the local mechanics to get a gearbox service...i'd been noticing some misfire/power drain in lower rev ranges for a couple weeks... when i went to pick the car up, they reported that my alternator was dead.... sure enough, driving home I noticed the change, crappy idling and a power drain in the steering when turning corners.... alt was totally stuffed and needed new regulator and bearings. Now that its been reconditioned the steering is excellent and idle is all back to norm.... seems that perhaps the power steering doesnt like not having 14v avail to use.... anyhow its all fixed and running nicely so i cant complain... for now ;D
-D
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
