Oil/water Pump Upgrade
This subject is much written about, so I will keep it brief, if you want more info do a posts search ("Sydneykid" and "N1 oil pump").
1. N1 is for RB26's, there is no N1 stuff for RB20/25/30
2. All of the recent N1 oil pumps are designed for the large diameter (R33GTR or later) cranks and don't fit RB20/25/30 cranks. You need to buy (make) and adaptor (collar)
3. N1 water pumps actually flow less than standard RB26 water pumps. They are designed for sustained high engine rpm as encountered in circuit racing. Not driving in traffic, with the aircon flat out, on a 40 degree day.
4. N1 oil pumps do not flow any more than standard RB26 oil pumps. They simply have a higher rate pressure relief spring, so they hold a higher pressure. But only when the pump is capable of supplying sufficient flow to maintain that pressure.
5. If you want a higher flowing oil pump, then the aftermarket brands (Jun, HKS, Trust etc) are an expensive choice. Dry sump systems are not much more and give a far superior result.
6. Speaking of sumps, GTR sumps are not so good for circuit work. I wouldn't be taking a GTR anywhere near a circuit without bafffles. For any decent track time, wings, one way doors and baffles are essential.
:D cheers :D
Contacted a Nissan Dealer in Perth as well and was quoted the same price as Bu5ter. Just a matter of finding someone who can help you buy it at the listed price.
Cheers,
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
