I am in the process of installing 555cc nismo injectors in my RB25det. I have figureed out the following from searching:
555/370 * 100 = 150%
Therefore should I set the injectors to run at 50% in the injector correction table???
& What do i do about the injector lag time :D ?
Another thing worth noting is that I am also going to install a Z32 AFM. I know about setting the PFC for this, but others have mentioned that the Z32 may lean out my mixtures, is this the case?
https://www.sau.com.au/forums/topic/85033-pfc-settings-for-555cc-injectors/
it's the other way around mate. work out the percentage you old injectors were relative to your new ones. in this case 67%. i don't even think the injector correction goes over 100%...
as for lag time, can you use google? if not stop messing around with your ecu if you can, then use it, find the lag time, key it in to the PFC. done. now you will need to take it some where and get it tuned properly anyway.
if you really must drive there and are tight on funds i'd suggest install the injectors by all means, wire up the AFM plug too, but drive there with the old AFM plugged in. when you get there stop out the front, plug in the new afm, bolt it up and in you go. simple.
or you could just shell out and get it tuned ... I have 550cc injectors and a z32 AFM, no problems from here, cos I got it tuned ...
I am only asking as I need to be able to DRIVE to the tuners place. Offcourse I am planning to get it tuned, why else would I get bigger injectors????
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
