do you know if you've had the top 10x10 cells tuned for economy? my fuel economy is povo and sam is redoing it this weekend. http://members.dodo.com.au/paul/pics/paulr...e-lightload.jpg im getting those area's tuned for max fuel economy. mines a tad over 12:1 probably same as yours. i assume your o2 is working ok
https://www.sau.com.au/forums/topic/85049-cruise-mixtures/#findComment-1540062
hey ppls.
All you tuners out there, what AFM ratio are you running at cruise?
I think mine is about 13.2 : 1
I get crap economy  could this be why?
I have stock turbo, 260 poncams.
PFC
The Stagea runs 14.7 to 1 at closed loop cruise and idle. The R32GTST race car also defaults to 14.7 to 1, but it doesn't do much closed loop running or cruising.
It's been a while since I looked, but I can't remembr seeing anywhere in the Power FC mapping where you can change the closed loop aim from 14.7 (even with a Datalogit). So if yours is really at 13.2, then it's most likely not running in closed loop and the mapping changes will have some effect. But if it is running 13.2 in closed loop, then the mapping changes will have zero effect.
:D cheers :D
https://www.sau.com.au/forums/topic/85049-cruise-mixtures/#findComment-1540129
i came off 460km's to my tank with room for more last week ;)
admittadly im on the stock ECU at present but that means im staying off boost, and never going above 3000rpm... boost is the enemy of fuel economy
i should have tried that while i was using the PFC etc. Best i got then was 330 but that was with a stuffed O2 sensor and lots of boosting :D
https://www.sau.com.au/forums/topic/85049-cruise-mixtures/#findComment-1540183
K
Now I've heard a horrible story about leaned out cruise mixtures can burn out exhaust valves on engines with big cams.
Not sure whether I'd call my 260 Poncams big or not, or whether I'd call 14.7 that lean.
Any thoughts?
https://www.sau.com.au/forums/topic/85049-cruise-mixtures/#findComment-1540254
My yellow light normally lights up quite early about 40l used then I just fill it up on the E , I will fill around 45-47l max haha.
I thought I was doing bad with those 350km (I'm a student so not much highway driving) , since BP Ult petrol price went up to 126 cents per litre!!! ridiculous (In Perth)
https://www.sau.com.au/forums/topic/85049-cruise-mixtures/#findComment-1540389
Is Julian Edgar quoting 16:1 for a nissan? Is that cruise or lean cruise? Most cheap (non sequential) aftermarket computers wont cope with those kind of numbers. We continue to run lean cruise in most holden v8's with durations up to about 220deg at 50 thou as a rule of thumb. But this is only with sequential ECU's.
https://www.sau.com.au/forums/topic/85049-cruise-mixtures/#findComment-1540557
