Howdy all,
I have been a huge fan for years of the GTR32
I would like to purchase a Skyline GTR32 of no particular model year
But i wondered, for those with one or silimar, is it worth buying one?
Considering there age?
Is it just trail and error?
I have already had two tested and both came back with engine faults.
Thanks ;)
https://www.sau.com.au/forums/topic/85058-gtr32s/
Thanks guys for your responses (my computer crashed as i tried to reply).
yeah i spent $450.00 and got a 1989 model tested compression test came back low & had a list full of requirements. And a 1992 GTR32 that was said to be re built & R34 Turbo's, got test back 6th clyd had been blown and was running on 5 cyld's & didnt from was guy who tested wasnt R34 Turbo's afterall. Thus i did not purchase. So back to the drawing board hey! Fun fun!! Anyone know in melbourne who are pros at testing these cars?
https://www.sau.com.au/forums/topic/85058-gtr32s/#findComment-1540390
Just dont be fooled by all the Hype surrounding 89 models as 'crap' and 92 models as 'good'.
It only takes a second of detionation to hurt an engine, and trust me it can happen to anything once you start playing with them.
Buy on condition ;)
https://www.sau.com.au/forums/topic/85058-gtr32s/#findComment-1540514
Didnt want to turn any one off buying one. They are a great car, im going tonight to look at another, 1989 model, completly standard. Which is prob a good thing! Wish me luck! Will let yall know how i went!
I think before buying one you would get it tested! Thou might be a up front cost, in the long run it would be worth it! ;o)
https://www.sau.com.au/forums/topic/85058-gtr32s/#findComment-1541403
If you can find a RAWS, have a look at SEVS cars.
The guys have offered some excellent advice in my opinion. There is no such thing as a cheap GTR. You'll pay the price, one way or another. $25,000 should see you in an older model that has had most things fixed. Please steer well clear of the "BNR32, $17,000, I just imported it but am moving overseas, blah blah". The engine rebuild that car needs will take the total price up to $25,000ish.
And as PSI GTS said, 89 doesn't always mean a lemon. Japanese guys don't seem to look after their older cars as well as SAUers so perhaps keep looking for a private sale? I'd pass on the dealer - other than their statutory 3-month warranty there isn't much point in going to a dealer. Even then, in the event of a claim (clutch etc.) they will probably allege that you've voided the warranty by 'racing'. Old trick.
As the man said, buy on condition.
https://www.sau.com.au/forums/topic/85058-gtr32s/#findComment-1542889
I don't like being cynical but you'll get what you pay for. A genuine 120,000km car would be hard to find for $18,000 on road. Remember that every man and his dog has been looking for good value 89 model R32's for the last two or more years - the chances of finding a straight, rust-free, low km car that doesn't have any major problems are very slim in my opinion.
https://www.sau.com.au/forums/topic/85058-gtr32s/#findComment-1545526
i just thought it throw my two cents in.
i recently imported a 10/89 bnr32 from nagoya.japan myself. it had a combined kms reading of 152000ks on it (stock cluster and nismo 320 one). it was stock with an exhaust and suspension. and service histry from new to 2003.
i was abit woried to begin with. but it is spot on. no rust or repairs etc. it doesnt use any oil and the box is good.
i work in an import workshop and through my experiance 90% of modified ones that come in are rooted. unless they sold for 2 millon yen.
a good stockish one will go for about 850-1.4mill.
but the fifteen year rule is over.
so my advice is go for a good clean stocker with stock air filter in place.
at the end of the day you get what you pay for. everyone else out there is looking for exacly the same thing you are.
good luck :huh:
https://www.sau.com.au/forums/topic/85058-gtr32s/#findComment-1548407
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
