I'm having some problems when I go past around 4-4500Rpm after driving for a little while..
The car mis-fires and sputters ie. looses power.
I'm running 12.5psi making around 250rwkw on standared injectors, bigger fuel pump. exhaust,fmic,haltech e6k etc.
I searched and found that the problem might be the gap on my plugs is too big, so I gapped them down to .8. Worked when I went for a test drive, but still breaking down when I was out today...
Another thing, it has a custom intake plenum which has some small gaps around the gasket from not being tight enough on one side. And around number 6 injector doesn't have a tight seal and is sucking in some air..
could this be my problem?>
Any other ideas???
https://www.sau.com.au/forums/topic/85065-car-mis-firing-problem/
If the car been running good on the injectors for a while i couldnt see it being that unless they are dirty....i would say it will be coil packs. If u have a mate who can help u out try there coil packs.
I don't want to sound stupid, but it has two "igntion" packs or something screwed onto the rocker cover. I'm guessing they are supposed to strengthen the spark or soemthing?
Or am I way off?
I don't know anyone with a set of coilpacks that I can try, what does a new upgraded set cost roughly??
I doubt any fancier type of plugs will fix the problem..
A member here at massive trouble he swore was his coil packs..turned out to be split wiring on the pack loom, causing spark to earth under load.
One way to check that is to remove the spark plug cover.. put it back together, wait until its dark.. give it some revs and try and spot any obviously arcs, or if you can see any jumps in the packs.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
