Hi there..
Dont know if anyone will be able to help, but I have a 1991 Skyline GTS-T M-Spec, 4 Door Sedan... I recently fitted my amps etc. insto the boot, and all was sweet... But hten i thought it was time to bling it up a bit, so removed some of the panels i had made and carpeted them... when i refitted everything, i got wicked alternator whine... Anyway, to cut a long story short, i have tested all my gear and cables, to which none are at fault... I have had the alternator checked, and all was sweet.. I even tried a supressor on the alternator (and just about everything else) which didnt help... I guess my question was, has anyone else had noise issue with this model of Skyline, and did anyone have any luck fixing it? Would really appreciate any suggestions anyone might have..
Cheers,
Damo
https://www.sau.com.au/forums/topic/85095-noise-question/
How's your earthing points? Clean? Upgraded the battery earth?
i go the same thing aswell
i tried everything but still i cant get rid of it
might change the altinator tho and get that checked out
i guess i just have to get used to it i guess
could be the amp tho...
what brand is it?
https://www.sau.com.au/forums/topic/85095-noise-question/#findComment-1541992
yeah the earth points are all good aye... havent thought about upgrading the batteries earth though..
but i acutally unplugged my alternator to see if that would help (after haveing it prof. checked, to which it was all sweet)... most of the whine went away, but i still had noise... sounded alot like ignition tick actually...
sorry to hear others have the same prob, but kind glad to know i'm not the only one at least..
https://www.sau.com.au/forums/topic/85095-noise-question/#findComment-1542493
if your bored, and want a long read.. or perhaps even looking for some tips to try on your own skyline to sort these probs out, you can read post in the forum i have been trying to get help in...
http://forums.nzicemag.co.nz/viewtopic.php?t=4971
cheers,
damo
https://www.sau.com.au/forums/topic/85095-noise-question/#findComment-1542714
