Re-posting an old ad becuase I can't seem to edit the old one!!
PRICE $11,500!!
This will include a RWC and plenty of reg (until mid next year)
Details:
Particulars:
Model: 1992 R32 GTST
Colour Burgundy
Kms 131k
Trans: 5spd Manual
Modifications:
Highflowed RB25 Turbo (currently running 12psi)
RB25 Air Flow Meter
3” exhaust (drift style muffler)
Remapped ECU (Dr Drift)
Apexi AFCII (fully dyno tuned)
Larger Injectors
500hp fuel pump
Jap Boost Bleed Valve
New clutch
K&N Pod
Stiffer Shocks – Car sits very low (also supply std springs)
Camber adjustable arms (rear)
Full Viper Alarm, keyless entry
Apexi T/Timer
Grey/Black Powder coated stock rims
Clear front indicators
Larger Brakes
Full M-Spec body kit including spoiler
Interior
The inside is in immaculate condition, no tears or rips
Clarion head unit, amp and new clarion speakers and sub.
Boost gauge
Exterior
Just spent $1,000 getting all the paint fixed on the car including a respray of the front bar, rear quarter (to remove a large scratch)
Other particulars
The car has been regularly serviced at Chasers Tuning.
I have just had all the exhaust manifold and turbo gaskets replaced. New water pump, fuel pump, plugs installed. Only had premium lubricants and oils since I have owned the car.
I have owned 4 imports and know how to look after them so you can rest assured that the engine is bulletproof and doesn’t miss a beat!
I am taking delivery of a work car around mid Aug which is the only reason I am selling.
If you want a fast tuff looking R32 then this is the car for you.
Jevan
Email [email protected]
Edited by QuickR33Melb
https://www.sau.com.au/forums/topic/85142-modded-r32-gtst-in-melb/
I had a buyer last month but he said he couldn't get insurance cheap enough and his parents wouldn't let him get it without full comp insurance. Then I went to Perth for 3 weeks.
I have an offer that I am considering at the moment but it is still up for sale. I spent a thousand dollars getting all the paint perfect and the car honestly looks absolutely amazing. It looks like it just rolled out of the Nissan Factory except its a hell of a lot faster than a stock model.
Anyway if anyone is interested they can view the car in Ascot Vale Melbourne right next to the Flemington race track.
Call or sms me on 0413 689 302 to arrange a look
I've had a few questions in PM's about this. The VIN check said its was build in 1992, the car is registered as a 1992 and the interior (other than the blue dash) is like a all the other 1992-93 skylines I have seen. Anyway as I said in an earlier post I have a firm buyer at $10,500 and he expects to have the funds available to me by next friday now.
If anyone wants this car at this bargain price then speak now or pay 13-15k for another example with as many mods and faultless condition!!!
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
