  • Replies 47
Contact Details: [email protected] or ring me on 0400-77-99-78
Hi there, im sure most of you know the story. As a resolution a replacement vehicle from J-Land is on the way for me - I'm all smiles and credit the import company for their professionalism and efficiency shown in the matter. As for this beast it is time to split her up and move on..
I have attempted to list everything that I can think of, if there is something that I have failed to mentioned that your chasing please let me know. Photo's are easily provided for those with genuine interest. I do not mind sending via COD providing a small deposit is made into my account. Cheers!
Engine bay and Driveline
RB26DETT motor complete with factory turbochargers, loom, factory ECU and HKS FCON computer $6000
RB26DETT gearbox $1100
R32 GTR rear diff and cradle **SOLD**
HKS Twin air pods (needs new filters) $100
HKS ATTKD Intercooler piping for no AFM setup $150
R32 GTR Radiator $200
R32 GTR Fuse Box $80
R32 GTR Tail shaft $200
100mm Intercooler with decent sized dent **SOLD**
Air Condenser and Compressor $200
R32 GTR Fuel pump $100
R32 GTR Fuel tank $80
Suspension related
R32 GTR 16" wheels (need a clean and some decent rubber) $700
R32 GTR Complete set of calipers and cross drilled rotors (not willing to seperate) $700
R32 GTR Hubs $100 each
R32 GTR Rear Sway bar **SOLD**
Interior parts
R32 GTR Front seats $700 **SOLD**
R32 GTR Rear seats $350
R32 GTR Dash with no bubbles $200
R32 GTR Dash with clock $150 **PENDING SALE**
R32 GTR Centre console surround $100 **PENDING SALE**
R32 GTR Instrument cluster with 73,000km's $100 **SOLD***
R32 GTR Air conditioner console $200
R32 GTR Centre console gauges $100 **SOLD**
R32 GTR Steering wheel $100
R32 GTR Door trims $100 each
R32 GTR Rear trims $80 each
Body parts
R32 GTR Bonnet in white with latch $550
R32 GTR Grill (one clip broken) $100
R32 GTR Driver side fender in white $250
R32 GTR Passenger side fender in white $250
R32 GTR Front Bumper in white with N1 slots and lip $400 **PENDING SALE**
R32 GTR Rear Bumper in white $250 **SOLD**
R32 GTR Driver side door $250
R32 GTR Passenger side door $250
R32 GTR Boot with factory spoiler $250
R32 GTR Driver and Passenger windows $50 each
R32 GTR Front headlights $100 each
R32 GTR Indicators $150
R32 GTR Electronic mirrors in white $70 each
I don't know the story so what's the go with the car, did it get damaged in transit?
Do you have the body shell and full wiring harness as this is what I am interested in???
https://www.sau.com.au/forums/topic/85157-sold/#findComment-1543646
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
