  • Replies 47
Hullo.... was wondering if you still have the steering wheel? I am after a standard steering wheel to pass registration. My momo one is 5mm too small to pass inspection.
Also after: genuine standard nissan R32 fuel pressure regulator
Standard front
Standard water spray/ windscreen wiper bottle
Back windscreen wiper (doesnt have to work)
Would appreciate any help! Thanks
reply either to this or email [email protected]
https://www.sau.com.au/forums/topic/85157-sold/page/2/#findComment-1544106
Ok, I've received a few questions about the HKS piping kit. Basically it is 3" stainless steel piping to replace all the factory pieces as pictured. The piping meets the intercooler inlet/outlet and is designed for a motor that DOES NOT run air flow metres.
The orange colour in my opinion doesn't look the greatest, but it's only a paint job away from being another colour. All the piping is in good condition with no dents. I will supply all needed clamps and joins etc..
https://www.sau.com.au/forums/topic/85157-sold/page/2/#findComment-1546639
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
