plex 15th
At this stage I'll be there, I have the night off work but I am getting over a bout of food poisoning atm so I can't be sure I'll be right by then.
Brett and his R33 GTR should be there, and I've almost talked Ken into coming, but it'll depend upon if he has sold the GTR yet, R34 also sounds like he might be talked into it and bring down his WRX for its inaugural run.
Who else is thinking of going? it looks as if we might get lower temps. than the past few Wed. nights.
https://www.sau.com.au/forums/topic/8519-plex-15th/
  • Replies 261
Rhino,
It was quite busy last week, but still get 10+ runs in if your there early. I was told if we can get 10+ cars together they will give us our own lane, might be worth thinking about.
Works Auto,
Sorry to hear about the gearbox, planning a stock replacement or something stronger?
Hicks,
Tyres for the 16's, I'll try and find some. If you had better rims, like 17's or 18's then I have some waiting at my house. When you blow the turbo try and do it at the end of the track so you don't ruin the racing.:bahaha:
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/#findComment-124683
Guest Works Auto
Yes rb20det box is piss weak... IM trying one outta a r33 rb20e non turbo.
Apparently same box as rb20det . we will see.
RB25DET box costs $1500... too much for me at the moment.
I hit third pretty hard and heard a large bang. So i babied it home in 4th gear.
I think ive either collapsed a bearing or ripped third gear appart.
I'll have a look when i take it out.
https://www.sau.com.au/forums/topic/8519-plex-15th/#findComment-125262
On your standard turbo doing mid 13s hey....hhmmmm
GTSTVSPEC
ok :)
https://www.sau.com.au/forums/topic/8519-plex-15th/#findComment-126005
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
