plex 15th
  • Replies 261
Barries dyno is starting to become popular again, that's good. He is a weird bloke but very good at tuning.
240rwhp is decent, shows what it can do when you get the power to the road. I've got a bit more power but can't get it down, so my times are still shit. I'll try again tommorow.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126345
Yeah, he's very down to earth, he was the first person to tune my car, knows how to fix anything which is better than most. He's always busy though which can mean a long wait to get stuff done, but still one of the best tuners around.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126373
Rhino,
Cost is $30 to drive ($25 if ANDRA member)
Opens at 5pm
Racing Starts at 6pm
Need helmet and long sleeved clothes.
Unless we get 10+ forum members together then they will assigned us a normal lane, usually 5 or 6. 10 or more then we can ask for our own lane.
See'ya
:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126455
  Quote
Originally posted by RB20LagWagon
hahah, little r33 drivers dont think you ran mid 13s with stock turbo simon? thats pretty funny. Its all about the car, r33's are fatt. gotta produce power to move fat.
Watch your mouth boy :fight!:
Are you taking the boat down for a run?
I mean wagon...
Hey Skyzzer my thoughts exactly..
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126597
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
