plex 15th
rev210,
I managed to beat that R34 last time, I think I got lucky though. You better be quick though, sounds like he has got a big turbo and race tyres on order.
I doubt that the S-AFC will get you to 12's or 113mph, but you could be the fastest stock-tubo GTS-t around.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134761
  • Replies 261
Unless your using a shitload of Toluene, I can't see it making much difference unless you adjust your base timing. You should be able to run more advance with it in. But you weren't running full boost last time were you?
Maybe it's time for that FMIC?haha.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134859
See'ya:burnout:
20% or so is all that will be necessary. 4L in 20L of fuel is quite an eye opener. I suggest you try it.
I think I'll buy some nice rims and tyres before the fmic, after all both those mods are about looks more than anything :lol:
I ran around 10psi last time, on the 13.4 run. Thats what I consider to be 'full' boost.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134952
Rhino,
I know he was running only a FMIC and boost, putting out 208rwhp at the dyno, but he has ordered a big turbo etc, which should be going on soon. He's after big power, and he's got the money to do it.
Rev210,
I'll be keen to see the difference that the toluene makes to your times, if the difference is noticable then I may try it myself.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134969
Yeah, you can just buy it from the hardware store. rev210 has a place he uses, but most stores have it, works the same as an octane booster, but may provide more power aswell.
I'm planning on running the VP 103, but at $110 per 20 litres, it's only good for the drags.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-135163
Macka: dude most stores DON'T have it, I should know I've looked in just about all of them.
Makit Hardware in Balcatta next to marlows balcatta. bout $24 for the 4L tin. Compares nicely with the cost of VP 103 for smaller volumes and craps on it for octane and energy value, it's just not as 'green'.
It's well worth a try I have a litre in the fuel at the moment (20% mix) and it gives a good old kick.
I'm sure you will like the extra timing Macka.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-135197
Bringing two members together, I feel like a match maker.
Although Osc@r had problems with spiking I don't think this will be as bad on a stock turbo, I used one for a while and it seemed to do OK, but compared to an EBC they suck.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-136436
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
