plex 15th
rev210,
I managed to beat that R34 last time, I think I got lucky though. You better be quick though, sounds like he has got a big turbo and race tyres on order.
I doubt that the S-AFC will get you to 12's or 113mph, but you could be the fastest stock-tubo GTS-t around.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134761
  • Replies 261
Unless your using a shitload of Toluene, I can't see it making much difference unless you adjust your base timing. You should be able to run more advance with it in. But you weren't running full boost last time were you?
Maybe it's time for that FMIC?haha.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134859
See'ya:burnout:
20% or so is all that will be necessary. 4L in 20L of fuel is quite an eye opener. I suggest you try it.
I think I'll buy some nice rims and tyres before the fmic, after all both those mods are about looks more than anything :lol:
I ran around 10psi last time, on the 13.4 run. Thats what I consider to be 'full' boost.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134952
Rhino,
I know he was running only a FMIC and boost, putting out 208rwhp at the dyno, but he has ordered a big turbo etc, which should be going on soon. He's after big power, and he's got the money to do it.
Rev210,
I'll be keen to see the difference that the toluene makes to your times, if the difference is noticable then I may try it myself.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134969
Yeah, you can just buy it from the hardware store. rev210 has a place he uses, but most stores have it, works the same as an octane booster, but may provide more power aswell.
I'm planning on running the VP 103, but at $110 per 20 litres, it's only good for the drags.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-135163
Macka: dude most stores DON'T have it, I should know I've looked in just about all of them.
Makit Hardware in Balcatta next to marlows balcatta. bout $24 for the 4L tin. Compares nicely with the cost of VP 103 for smaller volumes and craps on it for octane and energy value, it's just not as 'green'.
It's well worth a try I have a litre in the fuel at the moment (20% mix) and it gives a good old kick.
I'm sure you will like the extra timing Macka.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-135197
Bringing two members together, I feel like a match maker.
Although Osc@r had problems with spiking I don't think this will be as bad on a stock turbo, I used one for a while and it seemed to do OK, but compared to an EBC they suck.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-136436
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
    • For future reference, if you need to use Deutsch connectors but don't have the proper crimper for the round style pins, you can get regular style crimp pins too
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
