plex 15th
  • Replies 261
Originally posted by GTS-t VSPEC
Although Osc@r had problems with spiking I don't think this will be as bad on a stock turbo, I used one for a while and it seemed to do OK, but compared to an EBC they suck.
I found it was all to do with the setup rather than the bleeder - I used to get spiking from 15 or 16 down to 10, changed dump pipe, turbo and some other minor pieces and now it spikes about 1psi
just a std run of the mill turbodumb gated boost controller, but keeps the boost up so thats what counts
ebc I'd be most happy with but $$$ (even though a mate was telling me last nite he's getting an avc-r locally for $400, the %$&*)
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136575
Don't know about the ticket thing yet.
I got to have dinner with the stones brothers team, Russel Ingal and the Ambrose boy on our table. I think Russel was impressed at the level of yahoo pissheads on our table chanting 'Russel! ...Russel!' Got to see his new BA falcon car, sit in it, try to look in the engine bay, spilt beer on it, tried to cut the cable ties that restrained the pedals and got the guys to sign my name tag so I can forge their signatures later and get into the pits if the chanting doesn't work.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136623
Originally posted by rev210
Macka: dude most stores DON'T have it, I should know I've looked in just about all of them.
Makit Hardware in Balcatta next to marlows balcatta. bout $24 for the 4L tin. Compares nicely with the cost of VP 103 for smaller volumes and craps on it for octane and energy value, it's just not as 'green'.
It's well worth a try I have a litre in the fuel at the moment (20% mix) and it gives a good old kick.
I'm sure you will like the extra timing Macka.
Thanks Rev..
will look into it.
I just wanna be able to run standard timing with no rattle :D
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136641
Macka,
I still think that VP103 is much better for the price. It is 107RON and 99MON, which is far higher than Toluene.
Toluene is good, but it is not designed as a race fuel, yes it has been used in race cars, but it is not a race fuel. If your after serious performance edge from fuel then go the VP 103.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136649
Toluene is 122 RON / MON 106.
RACE FUEL not RICE Fuel.
Toluene was used during the 'turbo era' of formula 1. Back when they were running 5bars(73psi) of boost in qualiying and 4bars(59psi) in race. The fuels were limited to 102 RON so 84% toluene and 16%n-heptane (has no octane rating to bring it back to 102). Making 1500HP out of little tiny engines.... ooooright!
102 octane and 73psi? the funny thing is the octane rating of toluene is only half the reason its a bloody good race fuel.
VP103 just a compromise fuel.
Formula one racing teams know it, now you do too.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136681
rev210,
As you well know it did not ever get 122RON in a knock-engine when used in the right mix. Are you suggesting that Macka use straight toluene, I didn't think so.
I know that it can be used in race cars, but there engines are designed to cope with it, ours are not.
VP103 is a better unleaded Race Fuel, because our cars will die on straight Toluene. In the correct mix, toluene will provide a RON of 100, which will give you a bit of extra bang, but not nearly as much as the VP.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136712
Let me assure you that the 'correct mix' of toluene can be higher than the suggested 100 RON without detriment.I'd suggest anything upto 40% or so can be tried.The higher mix will have low rpm and cold start issues but in small volumes for the race day will work out well if you tune the car for it. The horse power generated by the toluene is higher besides, it's a very high engery fuel.
For interest I have run a 30/35% mix , with no adjustments and no problems.
VP103 is not bad compared to the old AVgas, it makes a bit more power and is unleaded.
We can agree to disagree on which fuel to use. I will just keep handing you your ass with my much less modified car (hee hee..ho ..ho..)
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136736
rev120,
I'll be interested to see what times you get running the Toluene. 40% is too much for me, but if your happy to run it then no probs.
We always disagree on this issue, but that's OK.
I think the 100RON was with a 25% mix, so your right, with more Toluene you will get a higher RON, but I've never heard anyone recommend higher then 30%.
Don't get upset if you less modified car burst into flames while doing a run on 40% Toluene.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136745
You wish!
Toluene is much less volitile than VP103, the formula 1 cars had the fuel tanks heated by the exhaust to get the stuff to burn propperly. If anything running too much toluene will prevent your car from starting and your engine won't be able to combust it, ie: unburnt fuel the opposite of ping.
I disagree because I've used them both. I pick toluene for cheapness and better power.
VP103?
Go kiss it in a tree!
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136763
I'd suggest that before anyone else tries 40% toluene that they ask there tuners, can't imagine many of them would recommend this approach.
I was only joking about the car blowing up, I wouldn't want to see you in flames, only the ones we trade in the posts.
So you running next week with 40% toluene? I'll be there expecting big things.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136776
Ask tuner's who have used toluene you mean. There are plenty of them that talk out of thier asses, even the good ones. Make sure the tuners don't sell VP103 or Elf either otherwise you might find them a little bias.
Then again you can try a litre or two from Makit hardware at 10% or so and see what you reckon
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-136801
yeah you want the % to be a little higher.
If you are a scaredy cat then start with 10%, I don't think that will make anything 'feel' different but, it will allow a snick more timing. After you have tried 10% then get 25% or 30% in there and you should 'feel' something, you can advance the timing a bit (obviously not too much cause it will ping). I advance mine till I just start to get a ping then back it off a little.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/11/#findComment-137296
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
    • had mine powder coated a hundred years ago [ok, over 20 years ago] and they are fine
    • Just want to say that the wheel choice is... choice 😅 What a beautiful example of a tastefully modded 32GT-R
    • never been do they do mid week track days.. I am just about to ordered Nismo suspension arms I might have to put them in use,,  I've been looking at you You tube Vids..lol
