plex 15th
rev210,
I managed to beat that R34 last time, I think I got lucky though. You better be quick though, sounds like he has got a big turbo and race tyres on order.
I doubt that the S-AFC will get you to 12's or 113mph, but you could be the fastest stock-tubo GTS-t around.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134761
  • Replies 261
Unless your using a shitload of Toluene, I can't see it making much difference unless you adjust your base timing. You should be able to run more advance with it in. But you weren't running full boost last time were you?
Maybe it's time for that FMIC?haha.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134859
See'ya:burnout:
20% or so is all that will be necessary. 4L in 20L of fuel is quite an eye opener. I suggest you try it.
I think I'll buy some nice rims and tyres before the fmic, after all both those mods are about looks more than anything :lol:
I ran around 10psi last time, on the 13.4 run. Thats what I consider to be 'full' boost.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134952
Rhino,
I know he was running only a FMIC and boost, putting out 208rwhp at the dyno, but he has ordered a big turbo etc, which should be going on soon. He's after big power, and he's got the money to do it.
Rev210,
I'll be keen to see the difference that the toluene makes to your times, if the difference is noticable then I may try it myself.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-134969
Yeah, you can just buy it from the hardware store. rev210 has a place he uses, but most stores have it, works the same as an octane booster, but may provide more power aswell.
I'm planning on running the VP 103, but at $110 per 20 litres, it's only good for the drags.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-135163
Macka: dude most stores DON'T have it, I should know I've looked in just about all of them.
Makit Hardware in Balcatta next to marlows balcatta. bout $24 for the 4L tin. Compares nicely with the cost of VP 103 for smaller volumes and craps on it for octane and energy value, it's just not as 'green'.
It's well worth a try I have a litre in the fuel at the moment (20% mix) and it gives a good old kick.
I'm sure you will like the extra timing Macka.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-135197
Bringing two members together, I feel like a match maker.
Although Osc@r had problems with spiking I don't think this will be as bad on a stock turbo, I used one for a while and it seemed to do OK, but compared to an EBC they suck.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/10/#findComment-136436
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
