plex 15th
rev and I just make this shit up, then we watch you guys blow your cars up, haha.
No seriously, mine is through a shit-load of reading and hanging out with mechanics and tuners that do race cars and such stuff. It's amazing what you pick-up. Toluene is not bad stuff in the right dose, and if kept at 30% or below will be fine, might give you the edge you need to sneak into the 12's etc.
I'm not keen on changing the timing on the fly, but rev210 is, and he seems to do it quite sucessfully. My approach would be to add a toluene mix to you tank, have it dynoed with the timing advanced, mark where the CAS should be, then when you go down the plex you can safely adjust the timing if you run toluene.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137379
  • Replies 261
JimiH I think they just read comics!
I dont trust dynos to give proper load values, when i set up my Haltech computer on my first car the WHOLE thing was done on the road then fine tuned on dyno...
I would only change Timing on the road as this equates to realtime changes..unlike a rolling dyno
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137442
I think Macka is weighing the car down, Fat Boy Racing, lay off the beer and chips and you'll be doing mid 12's Macka.
Tuning a car on the road is a good idea, but it means that you will only hear pinging once it is quite significant. On the dyno you can get microphones to detect it at the earliest onset, and therefore do not damage the pistons.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137529
I really think you should know how to adjust the timing on the fly.
This is something fundamental that everyone should be getting their hands dirty with.
When I go to the drags I take my timing light along and do a check before I start. With wear on the timing belt and things the cas position may have to be changed slightly to get the same timing over a period.
The marking on the cas is only a guide, ALL timing should be set using the gun based on the reading you have off the crank markings. And timing ought to be set properly on the road. You can adjust it according to conditions of temperature as well.
As for knowing so much: The more I learn the more I realise I don't know very much. I get some insight for all the wasted years building cars with my mates (some for racing) and taking kilometres of skin off my knuckles.
I think there is no substitute for 'hands on' both for making you hate yourself for ever touching a spanner and understanding how things really don't work.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137534
rev210,
I agree that hands on experience is important, and I have quite often adjusted my own timing, but I still think that they should have someone with experience to show them what to do first.
I have my CAS fully retarded, so it can't move, and adjust timing via a laptop.
There are tremendous gains to be had by changing the timing for different fuels and air temperatures, but one must realsie that there is always an element of danger in playing with the timing. If your experienced like rev210 then it's not a problem, but beginners should make sure they understand the principles behind the changes they make before playing.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137546
JimiH ive been to 2 tuners and they both didnt hear pinging.....
No microphones just the one on the side of your head Paul.
A guy who was on the buffer yelled out turn it off its pinging......he was across the room!
Retarded it more......sweet......
Got home......cooler being night...good fuel.....pinging!
There goes my 296 horsepower..retard it by ear and now she runs sweet, no midrange but it is safer for me..
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137744
Originally posted by osc@r
haha..
there's a couple of "little hair dryer" girls getting ever so closer to breakin the 12's fat mack..  your reign as king is to be short lived..
what u laughin at.......?
13.4 @105 is hardly anywhere near 12.9 @113
I want to see Rev and PWPaul get 13.4s on different nights :D
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137753
geez that's not good!
I thought the tuners wore those headphones so that they can hear the pinging?
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137762
Originally posted by GTS-t VSPEC
rev210,
See'ya:burnout:
I should give you a fatboy sticker...haha
U would never need to change your CAS that would put your whole curve out Paul, u just need to up or down the timing at certain points in the map, Set a base timing of 15 degrees and then in the rev ranges u can run as much timing as you like!
Ud only change it if your Base timing varied from you 15degrees..
I could get back about 25hp from my 13Degrees to 18Degrees but i need to retard the top end.....cause thats where it pings, around 6000rpm
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137766
Guest KILLER-T
Well i had a bit of a play with my timing last wednesday night at the plex my first run felt slow so i advanced it by 2 deg on the fc commander did another run it was just under half a second faster so next run gave it another 1 deg advance the car was a bit faster again but i stoped there i was getting a bit worried about the amount of timing it was running at idle its about 17 deg advanced and then it goes up to 42 deg in the midd range and then starts to drop off as the boost kicks in. so by playing around with my car it managed its fastest time sofar 13.3 108mph :burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137918
Good work!
I expect you will be moving on to 12's soon?
Gotta be quicker than Macka, you don't weigh as much.:D
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137932
KillerT,
Well done on the times, very good. There are alot of gains to be had by advanceing the timing but as you increase the timing you increase the likleyhood of pinging. If you have a laptop or hand controller to adjust the timing then this beats getting out and moving the CAS.
See'ya :burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137949
See thats getting there...
What boost were you running mate?
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-137988
Killer that maybe because you maybe on the border of needing an external wastegategate.
If you tramp it boost doesnt rise as quickly so you keep your dialed pressure...on the street u usually take off slower then tramp it giving more time for boost to bleed high as u go thru gears....
This is what happens to mine altho it bleeds to about .9bar not sure if it is your problem or not....
It cant be electronic, if u dial in 1.1 then you should get 1.1 no matter if it is street or strip its still the same kinda road...
A little birdy told me you snuck in a Z32 AFM and Adj fuel reg...
Another dynotune and hp reading maybe?? do tell..
GTS-t VSPEC have you any decent input into this technical conversation?
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-138116
Guest KILLER-T
Yep i got the z32 afm and fuel reg it was done at barries dyno he didnt tune it up he just put it on the dyno to make sure it wasnt going to lean out. He did a power run for me and it made 304rwhp running 1.08 bar. Again the car didnt boost as hard as it does on the street the only reason i can think of is the car was dynoed in 3rd there is not as much load on the engine and i dont get as much boost up:rolleyes:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/12/#findComment-138129
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
