Hey Guys
Just wondering how to get to install a REAR Strut bar??? I had a look in the boot is their any other way to get to the top of the rear struts to install it??
Thanks
if u are talking about a standard one, it doesnt attach to the top of the struts, the bar itself is attached to a black bracket on either side, which is attached to the back of the strut tower on two studs either side, (in the boot) you can see it when u remove the boot trim.
if u have a brace that actually attaches to the top of the the struts, u can access them by removing the rear parcel shelf from inside the car.
have a look here: http://www.skylinesaustralia.com/forums/in...showtopic=82746
i put a rear strut brace in the back of my r32. should be the same if u got a r33 (i assume u have a r33)
not true, there are two types of rear strut braces for the R33.
one that sits on top of the struts (requires parcel shelf hacking)
and another that sits on 2 pairs of studs that sit on the rear of the struts and face backwards. (requires boot lining to be cut)
the latter is a bit more rare to find - u can buy a ~$200-$300 cusco one, or find one from a wrecked 33GTR or some 33GTST (series II)
Yeah want to install an aftermarket Brace on my R33. So basically i need to get to them from inside the car on the parcel shelf. I think R32 are different aren’t they as the 33 has the battery and fuses in the back.
Edited by the97skyline
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
