gday guys im lookin at r32 gts4s. ive found one and im just curious if you are able to switch between 4wd and rwd? i have a video of a r32 doing this and doing a rwd burnouit then 4wd takeoffs. ive also seen this advertised on a r32 gts4 as a cross over switch or sumthin. is it possible? is it recommended? cheers
https://www.sau.com.au/forums/topic/85220-gts4-question-can-u-have-it-as-a-rwd/
why?
if u want skids.. buy a gts-t.. if u want a nice solid launch, buy a GTS4 and leave it in 4WD.
the weight difference of the GTS4 will make it pointless having if you have any desire to run it in RWD for any reason regularly.
But yup, it can be done via a switch or fuse pull.
He is right
If you wanna be cool and do skips then don't buy a GTS4!
Mine came with a switch and i think i have used it like once maybe twice for the 18 months i have owned the car!
If you want 4WD grip get a GTS4 if you wanna go sideways get a GTSt.
End of story!
do what you want.
people always tell me to buy a rwd car when i say i run my GTR in RWD... but thats their opinon... i say do whatever you want.
but hey... i wana launch hard and i also want to drift and also do track work.... the GTR does well in all of em..
the gts4 is slightly slower then the gtst over the quartermile
To get the GTS4 in RWD simply either remove the fuse in the engine bay fuse box, or install a switch which cuts the circuit. I believe you have to reverse the car a bit once changing back to AWD. I am thinking of installing the switch in my GTS4 soon. With regard to a GTS4 not being suitable for sideways fun sometimes, this is simply incorrect, there is obviously more weight up front but all it takes is getting used to. Last time i checked a GTS4 weighs around 1480 Kg's with/without a driver (cant remember).
BUT if you plan on running around all the time in RWD it does seem quite pointless buying a GTS4, the only time i'd use RWD is for a bit of fun or perhaps a future drift meet - thats me though. End of day "up to you"....
Cheers,
Rhys
From Expierince on the issue does installing the switch damage or harm the AWD system in any way?
Also any further input into installing the switch, and any bad "side effects" on the GTS4 would help me and others. Certianly don't want to "hi-jack" your thread but it is an issue of query for me too, Thanks.
Edited by WhatBrake
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
