Just looked at auction reports and not many marks, came through 5 times so I assume who ever bought it for you didnt want you to pay too much and pay what the seller wants.
You will need standard, wheels, exhaust, suspension and some minor panel work, nothing to much.
  • Replies 43
Yeah, I knew about the fact that it went through 5 times. J Spec were my brokers, fantstic job they did aswell :)
I NEED those STANDARD Parts! Anyone with any ideas or suggestions PLEASE PLEASE Post! :D:)
UPDATE : Suspension is half way there thanks to Sydneykid. Just need some standard fron springs.
Wheels are fine, we just need to source some R33 GTST rims.
If you can help with these parts post here or PM me
Cheers
Chris :P
Spoke to previous owner and he actually had 2 complete sets of stocker suspension, but he binned it all age ago unfortunatly, sorry :D
Oh ok, thats a bit of a shame. Thanks for finding out for me though Ska ;)
Just because I can I'm going to post what I think my Stag will look like with the 260rs Bodykit
Now:
Then:
Still I'm not a real fan of the colour. I think I might change it. We will se how the dough fines out.
I have figured out that I will have around 6 grand to spend on the Stag by the time I get my P's. What should I spend it on?
6k.
well, put it ALL aside and get a manual conversion + PFC
Otherwise if no power target
Split dump/front
High flow cat
jap brand cat back (order now..it will take a while)
DFA and IEBC
Sydney kids FULL suspension set up
then splash the other 1k on some decent tyres and some other little goodies you may want...
Heres what I came up with -
- 260rs Bodykit
- Re Spray (Standard Colours)
- Racing Seats
- Black velor re-trim
- GTT Side IC
- Jaycar Gear (Boost controller etc.)
- CGC High Flow
- Tuning
- Cam gears
- Auto Trans Cooler
- Auto Vavle Body Upgrade
So thats it, I think it added up to around $5950 or something like that. What sought of power/400m times could I achieve with this set up?
(Remember that the car already has Exhaust, Coilovers, Mags)
Cheers,
Chris :O
Forgot it already had mods
Well in the end, it really depends what you want
Look in the thread "Get a stagea into the 13's"
The way SK talks about it, if you have a target power, get parts for that target power and dont spend top dollar
The way I said was, spend top dollar on parts, and have a power target but be aware that if you want more, you wont have to change the parts to better ones...
Sooooo
I mean, you seem to not be like me and have no power target but just want more power and handling and not care about looks.
1. If exhaust isnt turbo back, get frontpipe/dump and cat (big power gains there, and bottle neck for everything else)
2. Make sure to include caster bushes and sway bars in your list, they make a BIG difference (i can only speak about swaybars for now)
3. If your going to get a cooler, i would suggest to consider a front mount. GTR cooler with custom pipes (unless GTT cooler is fine for you (~200awkw))
Else, good luck with the car :O
Thanks AlexCim, had a look at the thread and am now left wondering, if I was to go for the GTR intercooler, what are its limits? How many kw's atw's can be obtained from it? :)
Edited by Stagea RS-Four
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
    • I've ordered a new fuel pump and plan to do all the fuel tank hoses at the same time. Those are the hoses I would rather not go on the road.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
