Firstly, I've been told R32 gtr rear sway bars are a good upgrade for a gts-t
how do these compare to the whiteline packages? (i'm only thinking about rear sway bar upgrade for now) the main attraction of gtr rear sway bar's are that they are cheap! and i'm not serious enough about drifting to make full use of adjustability etc. so i'm happy to go for a "half way" compromise.
I've been told a stiffer rear swaybar will increase oversteer (whilst a stiffer front swaybar will increase understeer) is this correct?
I've been reading into it a bit, and i've seen a lot of people overlook sway bars in their drift setup. So i'm just curious how useful swaybard upgrades are for drift (as opposed to track work).
https://www.sau.com.au/forums/topic/85236-swaybar-options-for-drift/
GTR swaybars are hollow, I think, as opposed to the Whiteline solid swaybars. Plus the 'Blade' ones have adjustable settings, so you can adjust it to your preference - see the swaybars thread that was recently posted.
Personally, I'd prefer to have new suspension components on my car rather than second hand ones whose history is not always evident - that's just my opinion though.
I've just ordered a set of Whitelines to replace my standard GTSt ones.
yeah, i've read the thread about adjustable ones.   I'm more interested in how a stock gtr will compare to the whiteline ones on a gts-t...
What do you mean by compare? Size? Weight? Effect? Cost?
GTR bars are hollow, so a size comparison is useless
Obviously being solid the Whiteline bars weigh more, around 8kgs compared to 5 kgs.
Effect, the GTR rear bar is barely an upgrade at all, less than 25%, you would hardly feel it. The Whiteline rear bars come in a number of diameters (20mm, 22mm or 24 mm) plus you can get adjustable (we use 22mm and 24 mm adjustable rear bars). The 24 mm bar on full hard gives a 300% increase in rear anti roll, which is more like it.
As for cost, stabiliser bars are the best bang for buck suspension upgrade you will find.
;) cheers :)
PS; Who told you "R32 gtr rear sway bars are a good upgrade for a gts-t"?
Edited by Sydneykid
thanks for the reply.
I can't remember who told my gtr rear swaybars are a good upgrade, though I do recall a few people discussing it on nissansilvia.com as an upgrade for S13.
I'll be ordering the whitline ones if they're as good as you say they are!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
