In the new HPI there was a article on a 2835, 3037 and 3040 turbos used on a sr20, the 2835 had more than 250rwkw with the 3037 only slightly higher but with a lot less low end response and the 3040 heaps more top but very laggy. It will be laggyer than stock but on a rb25 it shouldnt be too bad.
You really need to get a turbo that will make the power you want at a boost level you want to run. You could get a 2835 that will be more responsive and make as much power as the 3037 it would need to run more boost.
Driving through the hills shouldnt be a problem as with my turbo which only makes good boost a 4000rpm you just keep it in the rev range and hang on.
https://www.sau.com.au/forums/topic/8524-3037-on-rb25/#findComment-124132
Given the 2835 on sr20 was suitable then the 3037 should be OK on a rB25. However boost characteristics like yours wouldnt be suitable for me.
I may give you a visit mid year. I hang out with Chris a bit and seen some of your work. With the turbo and standard intercooler coming off my R33 I have been thinking about bolting them onto my R31 Wagon and running low boost. Not looking to build a weapon just give it some overtaking power when towing. So would need some pipework. Cheap and nasty as possible.
I still have to way up the pro's and con's if its going to cost too much I wont bother.
https://www.sau.com.au/forums/topic/8524-3037-on-rb25/#findComment-124137
I've seen the 3037 on an RB25, and aslong as you have a decent exhaust manifold then it will spool up relatively quickly, about 3200-3700 depending on setup. To maximise spool-up, improve the intake manifold, exhaust manifold and port and polish the head. This should give you the 3200rpm spool-up. Will also depend on the ratios of the housings, smaller exhaust housing will spool quickest.
Should produce shitloads of power, even at relatively low boost.
See'ya :burnout:
https://www.sau.com.au/forums/topic/8524-3037-on-rb25/#findComment-124233
It wasn't too bad down low, but at 3000+ as the revs climbed then you had to hang on pretty tight. Car feels good, it's probably worth holding normal gear changes off for an extra 1000rpm, so that you always near the boost when driving. That is instead of doing 60km/hr in 4th, do it in third and you'll be closer to the power, makes for fun driving.
Still a very streetable car, not the same if on a 2litre, then the boost comes on all at once, much more difficult to drive.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8524-3037-on-rb25/#findComment-124689
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
