The 600cc injectors on my GTR are well and truely maxed.
I am after a set of injectors (probably somewhere around 700-750cc) that will fit straight into the factory rail and plug into the factory loom.
I don't want to have to mess around.
What can I use?
Also, will a nismo fuel pump flow enough to service these injectors. IIRC, they flow 276L/hr.
6 x 750cc injectors -> 4.5L min at max duty
-> 270L/hr
So, the fuel pump should be okay because the injectors will never see anywhere near 100% duty anyway.
Another option is to up the rail pressure, but I'd rather just get the injectors if they are a direct fit.
Would I be better off using a HKS or Trust rail and injectors?
https://www.sau.com.au/forums/topic/85274-injectors-for-gtr/
What can I use?
                            -> 270L/hr
the 700cc sards go straight in and are a good injector for the street driven gtr
the nismo fuel pump should be fine for these injectors if you run close to std pressure as my std pump services them up about 80% duty at ~530rwhp so a nismo pump should be fine at the same pressure but if you turn up the pressure the flow capiability of the pumps reduce accordingly.
pete
do your 600cc injectors tick?
is that how you know they are maxxed?
whats the size of the std GTR injectors?
sorry about all the questions its just that mine are ticking and its pissing me off
I would like to change mine to a bigger set, but I have no idea what to look for or the prices!
help appreciated
Tom
pete
Thanks Pete...so the plugs are the same too? If yours only run at 80%, they should be big enough for me.
Is the 276L/H at 12 volts or 13.8 volts?
Do you have a separate relay and wiring back to the battery for the fuel pump?
Or are you still using the factory wiring?
:blink: cheers ;)
Edited by Sydneykid
:blink: cheers  ;)
No idea what voltage the pump is rated at, but I'm guessing it would be at more than 12.5 volts.
I was considering running a seperate relay some time ago, but the thing is, on the BCNR33, with the battery in the back, there is only about 1/2m of cable between the battery and the fuel pump anyway.
When I saw this, I measured the voltage drop and it was less than 0.1 volts...Hardly worth the effort.
I suspect that doing this will be much more worthwhile on a BNR32, since the battery (and fuel pump relay at a guess) is at the front.
Interesting, how did you measure the voltage drop?
On a 1996 R33GTR, if I measure the voltage at the positive terminal on the battery with the engine running at 6,500 rpm on the dyno under load, it reads 13.8 volts.
If I measure the voltage at the positiive terminal on a Bosch 044 fuel pump, same conditions, it reads 12.3 volts with the standard wiring harness.
If I measure the voltage at the positive terminal on the same fuel pump under the same conditions, it reads 13.8 volts with a relay and a 30 amp wiring (with fuse) back to the battery.
With a lift pump, surge tank and a pressure pump, the voltage drop is even more noticeable via the standard wiring. You can even fell the wiring harness get hot when the pumps are working hard.
:blink: cheers ;)
:blink: cheers  ;)
Hmmm...I think the issue may be that the 044 draws much more current than the OEM pump...and this is compounded when you run two pumps off the oem wiring. But 1.5 volts drop seems huge for such a short cable. Maybe the ralay on that car was on the way out?
I measured the voltage at idle...but this shouldn't make a difference, becasue if anything, the pump will draw more current at idle, because it is under slightly more load.
On another note, I considered using an 044 and a surge tank setup. But my question is, will my oem pump keep up with the 044 (in order to keep the surge tank full?) I know it will not face any presssure, but will that increase the flow by that much?
Wih that setup, I would definately run thicker cabling, hot wires and fuel in a boot aren't a good mix!!
I run a stock pump in tank lifting to a 2L surge tank and then an 044 and it has run on long dyno stints etc without a problem at all. I am also running Sard 700cc injectors.
Stock pump is being powered by standard wiring + relay, 044 has its own wiring.
Pics of the whole shebang...
Shebang #1
Shebang #2
Edited by Amaru
I measured the voltage my pump was receiving today.
11.1v using the supplied earth at WOT.
11.68v using the chassis as the earth at WOT.
~12.6v at idle. Still a little low, it should be what the battery is, 13.8v.
Battery is at the front, running the std. internal pump with an external bosch pump.
At WOT you are running a higher fuel pressure. (Base pressure + boost entering the engine). Higher fuel pressure at WOT = higher fuel pump load and current draw at WOT.
Edited by Cubes
Will Sard 800cc injectors fit into the standard GTR rail?
    • Yeap, not as doorty as ITB's, but alot more doorty than before, induction sound great when I'm up it 馃
    • Any difference in induction noise?
    • If I got a dollar for every flipped commuter missile I've driven past I'd have two dollars   Some people get into wild adventures on the road and I doubt it's gender or ethnicity specific. I'm just glad I don't usually drive during peak times.
    • Just got the car back and gave it a good run back home Power wise, whilst it only made a extra 5 killerwasps up top at 7200 rpm, it made more power everywhere from 2500 rpm and kept pulling much harder all the way, to the point of me relearning when to shift so I don't hit the 7200 limiter, with the old intake it seemed to take alot more time to rev out, and, throttle response is also much improved  As I didn't want to remove the bumper every time I serviced the air filter (basically every aftermarket and fabricated CAI has the filter behind the bumper) it currently has a hektic exposed pod in the engine bay sucking in hot air, this will be rectified shortly after some some of my CAD (cardboard assisted design) for a alloy heat shield feed by the OEM intake tube behind the bumper, this will cop some wrinkle black paint, as well as the intake pipe for that totally OEM look... The only fly in the ointment was that the OEM "strut" brace doesn't fit over the rear runner of the new intake with the 2.5 engine is in the engine bay, as the 2.5 raises the engine up by 20mm, it's not a war stopper, and I didn't notice any difference without it in some twisties, but....... MX5 Mania is bringing in some GWR "fancy pants" braces that apparently do fit, if it bolts up I'll grab it, it is also stiffer than the OEM one, which is a bonus All in all I'm happy with the outcome      Fancy pants "strut" brace that gives the required clearance      This is where the clearance issue was, the GWR extends out past this
