moyseybike Posted March 26, 2012 Share Posted March 26, 2012 Cheers for the sweet info guys, made my weekend much easier;) As did the Aerpro adaptors, one from nissan loom, one from JVC headunit, plug in and done!! Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6290513 Share on other sites More sharing options...
DELLER Posted June 24, 2012 Share Posted June 24, 2012 hey alexcim thanks for your write up it helped me so much it was my first time changing a headunit in a c34 thanks heaps Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6413631 Share on other sites More sharing options...
Waino99 Posted August 25, 2012 Share Posted August 25, 2012 You are quite lucky that i have a big hole in my dash. Here is a photo of the power antenna wire. As i said, the wire for it is taped to the antenna wire (which in my case bends downwards). The two wires are then covered in some foam stuff and go up and to the left...or the right, i cant really tell. That black/yellow wire is what you attach to the antenna. If that wire is not attached (like mine), you will get terrible reception (in dips in the road/under bridges etc, reception will cut out. When you do attach it, it really REALLY makes listening to the radio a lot better. I am just lazy to fix it for now. Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6503484 Share on other sites More sharing options...
Waino99 Posted August 26, 2012 Share Posted August 26, 2012 This thread has help so much! When I'd got the motivation to do it it took ten minutes to pull it all out replace a fuse and now we have sound! Heaps better than listening to the iPhone speakers! Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6504409 Share on other sites More sharing options...
Jamesk89 Posted January 22, 2013 Share Posted January 22, 2013 This Aeropro loom Part Number APP0120 does that suit the plugs from the cassette player under the xanavi unit Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6716776 Share on other sites More sharing options...
flavzz Posted February 13, 2013 Share Posted February 13, 2013 Thanks heaps for the advice on this thread, I just installed a JVC media unit in under an hour which for me is great. Luckily the existing loom from the stock kenwood deck clipped straight in. Cheers Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6749861 Share on other sites More sharing options...
wolverine Posted February 13, 2013 Share Posted February 13, 2013 After market Kenwood to JVC worked for me the other day. The only difference was the two pins for steering wheel remote buttons was the only difference and I have none on the Stagea. Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6750075 Share on other sites More sharing options...
flavzz Posted February 17, 2013 Share Posted February 17, 2013 After taking out the stacker in the boot section of the stag there are 2 ugly brackets left which appear to be glued to the floor! Anyone had experience removing these without destroying the carpets? Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-6755345 Share on other sites More sharing options...
SpartanAir Posted May 16, 2014 Share Posted May 16, 2014 Just found this write-up, thanks so much for this post! Much easier than other cars I've worked on. Discovered the antenna issue, just ordered an adapter on ebay. My next step is installing my sub, amp, and speakers, I've heard you need spacers for them. But I'll cross that bridge when I get there. Cheers! Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-7285378 Share on other sites More sharing options...
Surrufus Posted October 10, 2014 Share Posted October 10, 2014 It might just be me, but when I look at the thread, all the photos are replaced with some kind of default grey imageshack ad. Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-7405510 Share on other sites More sharing options...
driftpig89 Posted October 8, 2016 Share Posted October 8, 2016 can we get the pics to this please just says 404 error Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-7782071 Share on other sites More sharing options...
spudtatoe Posted October 24, 2016 Share Posted October 24, 2016 We need updated photos... although I managed to swap the radio (even though i'm pretty sure I blew a fuse so it doesn't work lol) it would still be nice to have photos for others wanting to know. 1 Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-7786318 Share on other sites More sharing options...
soviet_merlin Posted January 22, 2023 Share Posted January 22, 2023 On 25/08/2005 at 11:33 AM, AlexCim said: Thanks to STAGE-A for the wiring 12V ------- Brown with white stripe Ignition -------- light blue with yellow stripe Lights -------- Red with blue stripe Earth -------- Just use the stereo metal brackets and heres the speaker connection wires (stagea s1 at least) left front ---- blue (+) black with white stripe (-) right front ---- brown (+) black with red stripe (-) left rear ----- mint green (+) black with yellow stripe (-) right rear ---- orange (+) black with pink stripe (-) Useful tip guys and girls: Always use a circuit tester as opposed to a test light, and always be very careful when doing so! Test lights, when used incorrectly, have been known to trigger air-bags, leading to a hell of a lot of wasted cash and a big clean-up, not to mention any personal injury that may occur when a bag goes off while you're in such close proximity to the dash and/or the steering wheel. The force and speed at which an air-bag inflates is not something you'd really want to experience first hand. Tip if your hookin up a DVD playa as i did and want to be able to play when your driving (not just when you have the foot brake on) simply connect the hand brake wire from the deck with the earth wire from the deck and earth them both together. simple!! WARNING technically this is illegal and im not advising you to do this if your screen is in the front. So lets get started ripping that sucker out! Pull out the ash tray and remove the screw from behind it Remove all your stuff from your centre console. Stick in the screw driver here. You can also pull from the indent thing where you put things, pull up. Make sure the car is not in park, otherwise it wont come out. I just put it in N or something Now that your console is off, unplug the ciggie lighter plugs from the back of it On 25/08/2005 at 11:34 AM, AlexCim said: Move the console off to the side, no need to unplug anything. I have extra stuff down there (hi/low boost switch) If you have two hands, i didnt (camera) put the screw driver in the two locations. Put them pretty deep so that they get behind the vent. The vent will just pop off once you have done that Remove the screws that hold the stereo surround on. Also there are some clips. On my car, they were really loose and easy to pop off It will just slide off now. There are screws under the above the frame of the units. Make sure you remove the lower ones first. be careful not to drop any. If you do, when you remove the whole unit you will be able to grab them. Once the screws are out, the unit will drop a bit. Its fine, dont get scared. The unit will now just drop off. Pull it out and do what is desired Screws for the stuff are on the side. When you remove things there are also "indents" that hold the units in. You MAY need to flex the frame a little to pull anything out (i was like wtf when i had to remove my DIN slot) To reinstall, follow the reverse. All the screws are the same, so dont worry about mixing them up. Good luck. I cant offer wrie diagrams as i didnt install the headunit myself, maybe someone else can post them here and ill update the post. Fixed photos in the quotes above. The original links are dead. Luckily they were captured by the internet archive. Link to comment https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/page/12/#findComment-7974920 Share on other sites More sharing options...
