  • 1 year later...
I just installed a cd/dvd/tv unit as well and I am wanting to hook up a reversing camera. Does anyone know which wire I need to attach the unit to to switch to the camera when I hit reverse?
Cheers
i powered my cam from the reverse lights in the rear door as i mounted mine just under the handle.
cool cheers, I was thinking I might put it there. I can use the reverse light wire at the rear to power the camera. However what about the trigger wire from the head unit? Where abouts is the reverse light wire in the dash? Is it under the centre console? Which color? (I haven't had a look yet, so it may be obvious to me when I take it out next. I just thought someone may be able to save me the trouble)
Thanks again
:P
  • 2 months later...
Can i get some kind of confirmation on the stereo wiring for the S2? Or if anyone knows of a adaptor kit?
I ask as i am lookign at a 2 din hole with two blank connectors, and i know i have 6 speakers (2 pillar tweeters).
Thanks in advance!
just a question for everyone in here who has taken there dash apart a few times, does anyone else have spastic cup holders? what did you do to fix them? mine sort of work but they hang to one side and look funy.
Thanks in advance!
You will only have 4 pairs of speaker wires, the A pillar speakers are "splits" with the front door speakers.
Has anyone put a double din head unit into a C34? Just wondering if there are any issues with it.
I've done it . Absolutely no probs, just follow the DIY. Get a plug to suit from JB, cut and solder.
Edited by 66yostagea
Thanks to STAGE-A for the wiring
12V ------- Brown with white stripe
Ignition -------- light blue with yellow stripe
Lights -------- Red with blue stripe
Earth -------- Just use the stereo metal brackets
and heres the speaker connection wires (stagea s1 at least)
left front ---- blue (+) black with white stripe (-)
right front ---- brown (+) black with red stripe (-)
left rear ----- mint green (+) black with yellow stripe (-)
right rear ---- orange (+) black with pink stripe (-)
On my S2, i found the RL & RR polarity was reversed to the above stated. and i also had two spare wires :)
  • 2 months later...
installed a new HU on the weekend
bought the Aerpro antenna adaptor, and found i got good reception even without combining both the antenna's
spliced into the black/yellow wire, and it seems radio reception is fine, haven't tested extensively yet
ran the ipod cable into the centre console, and a bluetooth mic into the exmpty switch next to the rear demister
lots of fun to work with. . . not!
  • 3 months later...
Quick question I need clarification on...
Will an S1 Xanavi unit be a direct swap into an S2 with the Factory CD/cas unit?
I believe it will. But why would you want the Xanavi unit anyhow?
just to let everyone know, there is probably an adaptor from aerpro that will plug into the stock harness
i dont know what the part number is but my r32 took the same part as a gq patrol which is about the same age so i would suspect that an adaptor is available to prevent having to cut and solder and also save time
Interesting...so Does the S2 car that has xanavi use the same looms/wires/sockets or whatever for air-conditioning... as one that didn't come stock with the xanavi unit?
No it does not.
One would require something like this: http://page5.auctions.yahoo.co.jp/jp/auction/e93993162
Ahh bugger. I'll be needing to buy one of them. Could you tell me the name of it so i know what to search for when it comes time.. please. haha
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
