I'm not sure hwo useful this will be cause each car will support different amounts of timing depending on mods. When my car was tuned I think it ended up with 14deg of advance, anymore than that and it was pinging, this was at 14psi.
I think the only safe way to do it is have it dynoed, then they can change the timing while monitoring the pinging and do it safely.
See'ya:burnout:
I think alot of timing issues have alot to do with plug heat range too. I moved to 7s and it pings at 11psi (17deg) I 'll be moving back to 6s to get rid if the pinging.
Of course there are alot of other issues as well but this is one that not many people think about in relation to timiing.
Doc
At present I have probably about 30degrees advance or so. I tuned my timing 'on the road', boost set to 10psi (spikes to 12 every now and then).
Doctor: I agree with the plug thing, going to 6's is a hotter plug, less suited to high revs and boost than a 7 or 8. But, its the range I am using with a gap of 0.75mm.
If you can be bothered an '8' range plug just for the races is a good idea if you can be stuffed changing them before you go home (i can't).
30 degrees advance? shit that seems like alot.
I didn't realaise that plug heat range had so much affect, we just gapped mine real close, don't have any problems with misfires. We tuned mine for 14psi, therefore I think the timing has to go back to reduce the chance of detonation, the 2psi extra pumps alot more heat into the intake air and promotes pinging.
See'ya:burnout:
My car doensnt go anywhere near 25 degrees let alone 30??
Paul your wolf does your timing anyway so your base timing should always be 15 and you set your advance up thru the rpm ranges hey..
I think its better tuned on the road the dyno cant reproduce all senarios but is good as a start
Macka,
I'm just going by what Steve(SST) said, I have no idea what it is. The wolf totally controls the timing, we moved the CAS right back so it wouldn't affect anything then adjusted the timing from the computer. Still think 30 sounds high.
See'ya:burnout:
The basic rule of thumb with ignition is:
Base timing --- advanced, more if you run a lumpy cam or have poor cumbustion down low.
Top end timing --- Retards as load increases and combustion mixtures become leaner or more prone to detonate easily.
As if my car wanted to prove a point I got a little bit of pinging today, I suspect it was the last lot of fuel I put in was a tad dodgy.
30deg advance means that when the ecu decides to penalise you for too much air flow you have beat it to the punch. Thats the therory I have worked on and it seams to be right. However I am open to what others have to say.
The more advance you run the higher the potential power output, but it provides a narrow margin for error in tuning. The potential of pinging at high advancement is increased significantly, and therefore minor things like and increase in air temp or slightly dodgy fuel can lead to major problems.
I have mine tuned on the safe side, I'm after reliable power without the worry of detonation. When it was being tuned there was quite a bit more power to be had through advancement but it started to ping, so we backed the timing off a little.
See'ya:burnout:
You tend to find 'worked' cars run a larger amount of advance in the bottom rpm range and less advance in the top end. When I say less I mean less than a stockie motor, with more boost and and higher cylinder pressures there is less encouragement needed to start combustion at the right time for best power.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
    • sensible choice....and all 32s should be in yellow
