Alright,
I want to go out on Saturday night but have absolutely no idea where is fun anymore cause I'm an old married bastard.
I'd prefer something with music but preferably not "Hey Mickey" or anything from the Grease sound track if you know what I mean. Dance, RnB etc - anything like that is good.
Also it can't be too a.n.a.l. as I'll be with a group of guys.
Will be starting in South Melbourne so prefer around there, city, StKilda or Chapel.
Suggestions?
https://www.sau.com.au/forums/topic/85303-where-to-go-out/
fitzroy street is always good, there are heaps of bars and stuff and you can crawl all the way along it. and if you get desperate at the end of the night there is always Traffic.... thats open till 5am or so everynight of the week. couple of bars up swanston street too like the lounge which is usually pretty laid back and cookie accross the road. thats all im going to write now, if i end up somewhere good tonight ill post it up
https://www.sau.com.au/forums/topic/85303-where-to-go-out/#findComment-1544717
What's wrong with 'Hey Mickey'?
And ZOS rhymes with Sh*thouse for a reason.
ZOS doesnt rhyme with shit or house...
dont go to zos unless your on the cookies, or the gear...or both
chapel, frostbites is good. half decent music (mix of rap/rnb and house)
you can go there earlier on for a meal...then stay for the club. upstairs is the house room now...
got the alcoholic slushies n shit...goes good
billboards...apparently its an older crowd saturday night...I go thursdays...big uni crowd, great night (im not at uni though lol)
https://www.sau.com.au/forums/topic/85303-where-to-go-out/#findComment-1545016
ahahahaha *breathes* hahahaHAHAHA Frostbites is a SH!THOLE. Go there and laugh at all the drunk feral country chicks and hillbilly losers who just jumped off a party bus. :P
As for ZOS, it's at 386 Chapel St, accross the street from KFC and Viper Room. It's where the legendary Chasers night club used to be! IMO ZoS went downhill after Dome shut down because all the junkies and drug f*kz 'migrated' to Zos. I've also noticed a bigger line in front of Viper lately than Zos. On top of that, I wouldn't be going to Zos these days anyway - can you say "Sausage Fest"? :lol:
Indeed, there are many class venues to go out on a Saturday night in Melbourne catering for all tastes in quality music and company. Andrew, I recommend you visit www.clubvibes.com for a run-down on the clubbing scene in Melbourne. Many local DJ's and promoters post details on upcoming events and opening club nights at various venues. There is also club night reviews, photo galleries and a message forum. Most of the forum goers are slightly house music genre biased but Clubvibes is a great source of information for clubs/bars/lounges in Melbourne. Check it out. B)
https://www.sau.com.au/forums/topic/85303-where-to-go-out/#findComment-1547208
D@MN Havent been to Jimmys in years!!! WEnt in last friday nite at midnight for 5 minutes!! WOW place is kickin hard, i think its dead on a saturday nite though. Thursdays and fridays are tops!!
If u just want to go ut and have an absolute ball with ya mates go to twister. LOL i dont think alot of people like Twister for sum reason but its tops theres plenty of hoes and the playground is BIG :)
https://www.sau.com.au/forums/topic/85303-where-to-go-out/#findComment-1548757
careful...the hoes aren't exactly over age just because they're inside ;) lol
how bout heat...goin there now
https://www.sau.com.au/forums/topic/85303-where-to-go-out/#findComment-1548760
so thats what this thread was about, i think my legs are about to fall off. i left at 5am and walked from fitzroy st to brighton and goto bed at 7:30. my feet are killing. top night guys. did ash rejoin or *cough* go somehwere cos i saw him out the front when i was leaving
https://www.sau.com.au/forums/topic/85303-where-to-go-out/#findComment-1549182
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
