The standard injectors in many Skylines are JECS.
So what that ad means is someone has taken a set of standard R33GTST injectors and had them high flowed by someone.
So the questions you need to ask is not "how good are JECS injectors", but "how good is the high flow job?"
:blink: cheers ;)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/85306-jecs-injectors/#findComment-1544710
I was watching these injectors too....
I thought its way too steep. You can get a set of side flow s15 injectors for about $400 from a wreaker... A set of 6 i mean...
Be carefull with S15 SR20DET injectors, the Australian spec S15 injectors are 370 cc's, same as RB25DET injectors. What you need are 444cc injectors from a JDM manual (not auto).
;) cheers :)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/85306-jecs-injectors/#findComment-1546302
are these any good? Can anyone say? I'm interested.
I don't know why you are bothering;
$US429 + $US13 for freight = $US442 = $A590 + 10% GST = $A650.
You can buy brand new Sard 63508's for $A686 from Nengun.
:P cheers :D
https://www.sau.com.au/forums/topic/85306-jecs-injectors/#findComment-1547660
but those need collars which require around another $300
I priced it and it worked out to be $900 all up. If I was going to spend $900, I'd get a set of nismos that bolt straigh in.
I contacted nengun and they didn't really have any idea if those sards would go straight in and just directed me to the collars.
And its risky, cause nengun doesn't have a returns policy..
SK, can you guarantee me that those will install into a R33 S2 without the need for collars?
If so, I would order them.
Edited by The Mafia
https://www.sau.com.au/forums/topic/85306-jecs-injectors/#findComment-1547997
The problem is there are a number of cars that use the same basic injector design, 1JZ 2JZ VG30 SR20 RB25 etc. Nismo obviously use the Nissan style, but the other manufacturers seem to prefer the Toyota style. Probably for volume reasons and the shear size of the US market for Toyota injectors.
That's why for the last 2 X RB25's we have done, I used S15 JDM manual injectors. At 444 cc's they handle as much as I would want out of a standard internals RB25. Once you start paying for engine rebuilds with forged components a couple of hundy$ for collars gets lost in the rounding.
;) cheers :)
https://www.sau.com.au/forums/topic/85306-jecs-injectors/#findComment-1548028
but wouldn't nismo injectors need replacing O rings to fit though ?
that's what i heard.
is this true ?
Only if your current O rings are damaged, or too hard from age and heat to seal properly. In which case they should be replaced anyway.
:) cheers ;)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/85306-jecs-injectors/#findComment-1548996
  • 3 weeks later...
Hi,
I saw this post and thought I would make myself available to answer any questions you all might have. IMO, Sydneykid hit the nail on the head... "how good is the high flow job" There are alot of companies out there that put out a product without any R&D, beta testing or quality assurance. I believe my processes and QA are industry leading. Every injector is flow tested, coil tested and matched to within a 3% variance. Plus an injector report is included with each set that shows you exactly what YOUR specific injectors flowed. The injectors are scribed with unique numbers matching them to the report.
Tang0 on this boad was one of the first people on here to use my injectors and I believe he was very happy...
http://www.skylinesaustralia.com/forums/in...hl=deatschwerks
**Moderators, if you feel this reply is inappropriate please delete. However, I have sent several emails inquiring about becoming an advertiser on these forums and I have not received any reply. I would be very interested in setting up a group buy.
https://www.sau.com.au/forums/topic/85306-jecs-injectors/#findComment-1591988
    • Don't they cool down technically when you're sitting at a set of lights?
    • The circuit if not a resistor divider is using an opamp to deliver a specific current normally. By maintaining the current as resistance changes, the voltage does too. Add to that, thermistors are normally non linear too,which can make creating a function impossible. Most uses of a thermistor people will utilise a lookup table to get the corresponding temperature.
    • On a scale of 1 to 10, how shit are the RE003's? (10 being ultra mega shit) Was hoping they'd be alright for a non-daily driven R32 that might get driven to Charnwood Macca's in the dry once a month, and maybe the odd hoon up and down the hills that pass for mountains in sunny Canberra.  Bob Jane currently running a "Buy 4 Get 1 Free" deal on RE003s and my brain can't comprehend anything else being value for money
    • Yeah, they look good. I should try to fit them on mine. But being a GTSt, the guard shape probably doesn't suit properly.
    • Nah, it's not a simple voltage divider. I'm not enough of an electronics guru to know how they make these circuits work. If I had a better idea of how the ECU's temperature measuring is done, I could then actually do as you want, which is turn that resistance chart into a voltage chart. But my approach has not worked. What I did was interpolate the sensor ohms values for the temperatures you listed, as you did not have any of them on a temperature ending in zero or 5. These are: °C ECU V sensor ohms (interpolated) 58 2.68 11.85 57 2.7 11.89 56 2.74 11.93 54 2.8 12.01 49 3.06 12.208 47 3.18 12.284 43 3.37 12.42 I then assumed 5V supply to the resister and calculated the voltage drop across the sensor for each of those, which is just 5 - the above voltages, and then calculated the current that must be flowing through the sensor. So you get:             Values in sensor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current 58 2.68 11.85     5 2.32 0.195781 57 2.7 11.89     5 2.3 0.19344 56 2.74 11.93     5 2.26 0.189438 54 2.8 12.01     5 2.2 0.183181 49 3.06 12.208     5 1.94 0.158912 47 3.18 12.284     5 1.82 0.14816 43 3.37 12.42     5 1.63 0.13124 And then use that current and the ECU's sensed voltage (which must be the voltage drop across the in ECU resister is there is one) to calculate the resistance of that in ECU resistor. You get:             Values in sensor   Other resistor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current   Volt Drop Resistance 58 2.68 11.85     5 2.32 0.195781   2.68 13.68879 57 2.7 11.89     5 2.3 0.19344   2.7 13.95783 56 2.74 11.93     5 2.26 0.189438   2.74 14.46381 54 2.8 12.01     5 2.2 0.183181   2.8 15.28545 49 3.06 12.208     5 1.94 0.158912   3.06 19.25592 47 3.18 12.284     5 1.82 0.14816   3.18 21.46325 43 3.37 12.42     5 1.63 0.13124   3.37 25.67816 And that's where it falls apart, because the resulting resistance would need to be the same for all of those temperatures, and it is not. So clearly the physical model is not correct. Anyway, you or someone else can use that information to go forward if someone has a better physical model. I can also show you how to interpolate for temperatures between those in the resistance chart. It's not fun because you've got to either do it like I did it for every 5°C range separately, or check to see if the slope remains constant over a wide range, then you can just work up a single formula. I'm just showing how to do it for a single 5° span. For the 58°C temperature, resistance = 11.77+2*(11.97-11.77)/5 The calc is a little arse backwards because the resistance is NTC (negative temperature coefficient), so the slope is negative, but I'm lazy, so I just treated 58 as if it was 2 degrees away from 60, not 3 degrees away from 55, and so on.
